Adjustable Push Rods - R they all the same
Old Mar 1, 2013 | 08:09 PM
dennyo's Avatar
dennyo
Question Adjustable Push Rods - R they all the same
Just Wonderin if I need to get new push Rods are some better than others ... Stage 1 , 88 , FI , .. Gunna check my cam chain tensioners Next Week , Don't have the Money todo the cams just gunna change the Tensioners and push rods if they are Bad , If there OK , I'll Check-Um in another 10,000 ..
Old Mar 1, 2013 | 09:04 PM
xwhyz1959's Avatar
xwhyz1959
I'm sure there are big differences in APR's. For instance, some are "fast install", whereas you still can use them with your existing pushrod covers. My only experience with them is with Smith Brothers APR's. I used them when I upgraded the inner cam bearings in my 08 FXSTC. I liked them so much that when I did the same to my 08 Ultra, I used Smith Bros. again. Biggest difference in APR's I believe is the threads per inch of the adjusters. That and some are just more robust than others.
Old Mar 1, 2013 | 09:10 PM
QC's Avatar
QC
If you go through the top, you won't need them. But if you have your heart set on them, I have Andrews aluminum and have had no problems in about 10,000 miles. Also would suggest the pushrod tubes for adjustables. Not absolutely necessary, but they lessen the hassle of adjusting. Prolly get plenty of opinions on this.
Old Mar 2, 2013 | 08:39 PM
dennyo's Avatar
dennyo
Thanks fur da Input ..... Don't no if I'll need-um-yet
anubisss
Feb 17, 2025 07:52 AM
briharley
Jan 18, 2020 06:54 AM
jcb1975@yahoo.com
Apr 4, 2012 11:06 PM
da_big_Guy
Aug 30, 2010 06:16 PM
bubbas1
May 20, 2009 08:34 PM
