Installing the 422's this weekend.
So do any of you guys have any guidelines for the rebound? Since it's a pain in the *** to adjust, I'm hoping to get it close to perfect on the first try.
I'm about 185 pounds and rides solo 95% of the time....
Here's a few tips that may help you.
For adjusting the preload, you can find some instructions in the service manual (and owners manual) on how to adjust the shocks, but they are not the greatest instructions.
So here are a few tips:
1) Jack the bike up so the rear tire is off the ground. Don't forget to strap the bike down. Try to position the jack so you have as clear access to the front of the shock canister as possible (the rnd of the shock towards the front of the bike).
2) Loosen the jam nut that is against the adjuster plate (the one with all the holes around it) all the way out. Its a 1-11/16" nut. If it doesn't want to loosen easily (which is often the case), soak it in some penetrating lube.
3) With a spanner wrench (HD p/n 94448-82B or an aftermarket spanner wrench that fits) turn the adjuster plate counter-clockwise (so the shock housing/adjuster plate moves towards the front of the bike) until its up against the jam nut. (Note: if you know the adjustment has never been changed, you can turn the adjuster plate clockwise until it bottoms out at the lightest setting (probably less than one turn) and then calculate your adjustment from that point).
4) Then take a light colored paint pen, or a piece of duct tape, and mark the 6 o'clock position on the adjuster plate to use as a reference point when doing your adjustment. Don't worry if they're not in exactly the same position on both shocks. Thats normal.Now your ready to adjust the shocks to your weight/load.
5) With the spanner wrench, turn the adjuster plate clockwise no more then 4 complete turns by counting how many times the mark from step 4 crosses the 6 o'clock position. 0 turns is the stiffest setting, and 4 turns is the softest setting.
6) While holding the adjuster plate in place with the spanner wrench, tighten the jam nut up against the adjuster plate by turning the nut clockwise.
7)Now repeat the exact same process on the other shock.
The key is to adjust both shocks equally.The general rule of thumb for adjustment is:4
4 turns for load less than 180 lbs
3 turns for 180lbs - 235lbs
2 turns for 235lbs - 300lbs
1 turn for 300lbs - 375lbs
0 turns for greater than 375 lbs
Examples:
235lbs solo rider: 3 full turns
235lbs solo rider + 32lbs pack: 2.5 turns
235lbs rider + 150lbs passenger + 32lbs pack: 0.5 turns
Also it may be a big help to get yourself an open end wrench that is 1-1/16". The one that comes with the 422's is very difficult to use. You can also cut the wrench in half to make adjusting the preload easier with the bike on thr kickstand.
Hope this helps.
So, if you are not aggressive on corners, the 422 will be a great improvement for the price.
klf33: What do you mean "4" and 1,4" ? Is "4" the stiffest setting?
And yeah, maybe I'll go with the shotguns when I get a new rear fender in the future, but as of now, I'm pretty shure I'll be happy with the Progressive's.
Examples:
Hope this helps.
I tour a lot, solo and 2up, not every local indy shop or dealer carries spare parts for an aftermarket air ride suspension kit, I blow a seal on Softail shock or have an issue, I can be up and out of a dealer most likely the same day. I feel there's a lot more that can go wrong with air then a gas charged shock. JMHO.
