Alignment?
Old Apr 20, 2013 | 09:52 PM
brettnbama's Avatar
brettnbama
Default Alignment?
So the front and rear wheels were off the crossbones. Is there any kind of alignment or anything that needs to be done?
Old Apr 20, 2013 | 09:55 PM
redmosquito1's Avatar
redmosquito1
Just make sure your spacers go in the correct orientation and they'll be fine
Old Apr 20, 2013 | 09:58 PM
Sgt_Jim's Avatar
Sgt_Jim
that's not exactly true.. especially with the rear wheel, because if it doesn't track straight (those tension bolts on either side of the axle) you can have issues with your belt tracking in to your transmission.. there's a few ways to make sure it's straight. I use the way that involves a laser and two cards with lines marked on them and you make sure the laser stays in the lines as you rotate the tire, which means your belt is straight. there's videos and stuff on youtube that show you different ways to do alignments
your front tire on the other hand, yeah, just make sure the spacers are on the right sides and you should be okay
Old Apr 20, 2013 | 10:22 PM
NoRegerts's Avatar
NoRegerts
Several different ways to align the wheels. American Iron magazine had a tech article i, I believe the May issue, which is still on shelves.
Biggest thing to be carful of is the rear wheel, and making sure the belt tracks in the center of the pulley and doesn't rub the pulley sides when the wheel is spun in both directions.
Old Apr 21, 2013 | 10:32 AM
2010Deluxeguy's Avatar
2010Deluxeguy
don't the mechanics at your dealership know how to align the rear wheel?
Old Apr 21, 2013 | 01:18 PM
Bloozmann's Avatar
Bloozmann
http://www.mactools.com/shoponline/p...-davidson.aspx
Old Apr 21, 2013 | 07:15 PM
brettnbama's Avatar
brettnbama
yeah they do. I was mostly asking if it was necessary, not for a how to. We only have two techs on a Sunday, so I didn't want to bug them with it today unless it was necessary
Old Apr 21, 2013 | 09:29 PM
Mikey8717's Avatar
Mikey8717
Default Caliper
Originally Posted by brettnbama
yeah they do. I was mostly asking if it was necessary, not for a how to. We only have two techs on a Saturday, so I didn't want to bug them with it today unless it was necessary
it is necessary for the correct tracking as you know. i just use a caliper on the belt tensioner bolts. everybody has a way of doing it. Never had a problem with doing it that way.
Turbols1
Jan 1, 2017 11:31 PM
jworm1420
Jan 8, 2014 08:41 AM
redmosquito1
Apr 30, 2013 08:51 AM
busterman2
EVO
Aug 17, 2011 02:17 PM
Hoblick
Jul 26, 2011 07:42 PM
