Shotgun Shock Issues!
Old May 16, 2013 | 08:02 PM
klf33's Avatar
klf33
Just a question, what is the issue ? my understanding is that once it is set while you ride you should not be affected by anything electrical !.
Or were you trying to adjust it on the fly ?
Old May 16, 2013 | 09:00 PM
Kowan's Avatar
Kowan
The relay is zip tied to the rear lighting wiring just below my oil tank. It doesn't move around and I've had no trouble from it.
Old May 16, 2013 | 09:30 PM
klf33's Avatar
klf33
Mine is tucked in front of my Battery actually , not moving either, I am still not sure what is the 'issue' that happened while riding ? very curious to find out.
Old May 16, 2013 | 09:31 PM
Kowan's Avatar
Kowan
I'd guess loose connection from not being secured.
Old May 17, 2013 | 09:46 AM
Leech1107's Avatar
Leech1107
Thanks Kowan that is where i had mine. I wasnt sure if there was too much heat there to cause issues.
Old May 17, 2013 | 09:47 AM
Leech1107's Avatar
Leech1107
yes it is the adjustment on the fly.
Old May 17, 2013 | 09:51 AM
Ramboamt's Avatar
Ramboamt
Originally Posted by 2010Deluxeguy
Im not bashing, and I will own one at some point...but I have been on this forum for a few years, and there are more than 50 threads talking about how someone had to have a part overnighted to them because it was broken. Like I said in my post, JD's customer service is top notch. Im just saying that he might want to be looking for higher quality components to eliminate having to spend his time and money overnighting new parts to people...who knows, maybe he gets the new parts from his venders at no charge, but would be better if they didn't break in the first place...I am also aware that many issues can be installation related since most of these are being installed by the riders themselves. I own my own company just like JD does, and I know that if I have to go back and fix something, even though I do it at not charge, I would surely prefer to not have callbacks at all. That's all Im saying.
JD has been upgrading the components on the SS system. When he installed our SS he stated that it had the latest compressor and the upgraded shock.
R&D is always an on going proposition with anything. I have designed and manufactured components used on RC, Remote Controlled, airplanes and I have tweaked some of them because of the feed back from my customers.
Then you look at the automotive industry they are ALWAYS upgrading and RECALLING their products.
The point here is what everybody else has said "The customer support is great"
I wonder how many SS systems have been installed over the years and what the problem rate is?
This is my
Toolmaster
Road Trips
25
Jun 21, 2020 01:28 PM
SteveHDVAN
Jul 31, 2018 07:42 PM
Sling Blade 14
Jun 12, 2016 03:24 PM
selfmade00
Feb 24, 2014 01:10 PM
tmultra
Aug 16, 2009 09:52 PM
