'13 Softail, busted ignition switch?
Old May 19, 2013 | 05:24 PM
jam436's Avatar
jam436
Default '13 Softail, busted ignition switch?
Just got back from a 2-hour ride today, and I went to park the bike in my garage and lock it up (like I always do), and for some reason the ignition switch cover won't latch shut. It feels like it's jammed somehow.
The lock works fine, it's just that the cover won't close.
Anyone ever see this? Anything to look for, because I'm at a loss...?
It's covered under warranty, no problem there, I just hope I don't take it to the dealer and have them tell me I may wind up with a second key because they don't feel like matching it to the original...
Old May 19, 2013 | 06:58 PM
daleone3's Avatar
daleone3
Stage I
Default ignition switch
the only thing it could be is there is probably a pin that holds that on and the pin may have slipped up or down and hitting something else to keep from closing. if you try to force it, it will probably bend whatever is going on. see if you can move the pin with a paperclip or something similar.
Old May 19, 2013 | 07:33 PM
jam436's Avatar
jam436
Figured it out. Inside the stationary part of the switch there's a small groove with a tiny horseshoe-shaped spring clip. The cover has a pointed pin that's supposed to snap into that. Somehow, that spring clip got bent, preventing the pin from seating. I could see both ends of the clip through the slot on top. I just straightened it out with a small knife blade...
Jumpman
Aug 14, 2017 09:57 PM
Bill918
Mar 21, 2015 03:01 PM
uklauren
Jan 19, 2014 07:25 PM
heritageblue2013
Jun 4, 2013 09:16 PM
pitbulldog
Sep 28, 2010 08:27 PM
