Weird Primary noise
Old Jun 3, 2013 | 08:43 AM
arighi's Avatar
arighi
Default Weird Primary noise
Ok, so I am new here and I hate to think that this has been asked a 100 times, but I cannot find an anwer to this.
I have a 07 Softail Standard with 13000 miles. I have had it for about 2 months and love the bike. Runs great. I have done all of the fluid changes a couple weeks after I bought the bike. I just wanted to be sure that all fluids were fresh.
The question I have is regarding the primary. I have actually changed the fluids in there twice. I had syn 20w50, but thought it was a little noisy, so I went to redline. It is a little quieter, but my concern is when the bike is warmed up. It seems that the primary gets noisier. At first it sounds like a sewing machine, but then it gets a little louder than that. The bike shifts great and do not have any issues there. I have also noticed that If I really get on the gas coming out of first and second, sometimes I get a pretty high pitch noise??
I just want to know if I am hearing what may be considered normal noises, or should I be concerned here?
thanks in advance.
Old Jun 3, 2013 | 09:01 AM
cuda67bnl's Avatar
cuda67bnl
Have you adjusted the chain? If not, do so.
Old Jun 3, 2013 | 09:29 AM
MattG1329's Avatar
MattG1329
Compensator nut coming loose?
Old Jun 3, 2013 | 01:48 PM
arighi's Avatar
arighi
Thanks for the replies, but from what I read, the chain has an auto-adjuster. As far as the compensator nut? Where do I find that, inside the primary? so i would have to take the primary case off in order to take a look at that?
Old Jun 3, 2013 | 02:18 PM
Car Doc's Avatar
Car Doc
Mine sounds like its whirring all the time even with the clutch in fwtw. So I know its primary only but I cant help either one of us just making a comment. Someone on here will help ya though it may be normal for all I know good luck. edit: My bike has about 24k on it btw.
Old Jun 4, 2013 | 08:49 AM
cuda67bnl's Avatar
cuda67bnl
Yes, it does have an auto tensioner. But that doesn't mean it's working correctly. Next time you change your fluid, pull the outer primary cover off. You can re-use the gasket, so don't worry about buying another one. With the cover off you can inspect everything. It will only take about 30 minutes and you'll have some piece of mind afterwards.
Old Jun 4, 2013 | 09:09 AM
Car Doc's Avatar
Car Doc
Yeah I am thinking mine sounds like its tight so next primary oil change I am pulling the cover and check it.
fwtw I heard a noisy primary on a video on here another thread on noisy primary's in touring bikes and wow if mine sounded like that one I wouldn't be waiting!!! Some guys were saying it was a normal sound but I disagree. my .002
Old Jun 4, 2013 | 11:22 AM
nightrain1983's Avatar
nightrain1983
I just had mine put in the shop with 22k miles for a similar noise. They said it was a transmission main bearing
Ron Carlson
Mar 29, 2020 11:32 PM
xwhyz1959
Aug 3, 2013 07:15 AM
arighi
Jun 4, 2013 08:57 AM
brown dawg
May 28, 2012 01:30 PM
Blueharley
Jun 27, 2008 01:05 PM
