A lot of discussion on puttling pull back bars on a Fat Boy Lo. I have a 2012 Fat Boy Lo with ABS and I just put on the Chubby 560 bars and had the turn signals relocated. Guys made some custom mounts for the lights that I am going to have powder coated. No issue with the cables what so ever. Everything stock worked fine.
Huge difference in comfort of how it rides. I am vertically challenged at 5'4"
Big fan of pullback T-Bars. The bend in the riser is a lot lower than in mine and it looks like there is a bit more angle to the cross bar as well. Looks good.
Did you try HD's pull back risers before you went with these? I'm asking because I went with 6 inch HD pull back risers with the stock bars and I still feel like I would like another inch or two of pull back. What's the specs on these? More pics would also be great. Particularly zoomed in to show where the grips end up in relation to something like the dash. That would help me get an idea of how much more or less pull back your setup has. Also be sure to subscribe to the calling all Fatboy Lo's thread if you haven't already. Lots of ideas for spending all your money over there
My initial plan was to go with the 4 in pull back risers however when I got to looking closer at it I was concerned if would not work as I had hoped. My neighbor has a cheap set of pull back bars that are taller with not as much angle. These are the low profile.
The 6" risers raise the bars. They really only bring them back MAYBE a couple of inches at best.
