Help with NOISE
Old Jun 11, 2013 | 12:44 PM
cravej1's Avatar
cravej1
I guess it would be the "Compensator Cover with Springs"
Old Jun 11, 2013 | 12:54 PM
cravej1's Avatar
cravej1
GOLFBLUES
Not a ping.
LOUD RATTLE under load coming from the lower left side (PRIMARY AREA) nothing at idle.
Old Jun 11, 2013 | 01:09 PM
golfblues's Avatar
golfblues
Originally Posted by cravej1
GOLFBLUES
Not a ping.
Actually I should have said detonation which is what I had. Sounded like a box of loose bolts under load on hard acceleration or wide open throttle in 5th & 6th gear. Came from the top left side too.
Did you pull the inner primary to remove the compensator? If I remember my springs were loose too when I replaced it with the SE comp.
jbyun
Nov 7, 2018 04:50 PM
Bayonet benney
Feb 27, 2014 08:21 PM
Rev zombie
Sep 20, 2012 03:38 PM
troy.j
Aug 25, 2012 10:58 AM
ohmatron32
Custom Models
Jul 13, 2006 04:37 PM
