2002 Deuce speedometer help. ????
Old Jun 17, 2013 | 01:21 PM
skullboy62's Avatar
skullboy62
Stage III
Default 2002 Deuce speedometer help. ????
02 Deuce. Speedometer has random operation. Jumps all over. I have replace the speed sensor 3 times, replaced wiring from sensor to speedo. Checked voltage from regulator was good. Checked all grounds. Works 80% of the time. New speedo part is not available from Harley. Want to keep my miles the same for bike value. Can I use a speedo from standard siftail the same year part # 67033-99? Or any help on this problem?
Old Jul 13, 2013 | 11:28 AM
DeuceRider01's Avatar
DeuceRider01
Stage II
Dakota Digital makes a digital one that is programmable for miles and has a tach on it.
Old Jun 11, 2014 | 09:04 AM
Serenity Now's Avatar
Serenity Now
6th Gear
My 02 Deuce has speedo problem too. If I didn't want to spend $ on teh Dakota Digital what part number speedo will work? Mine is carb. Found this on eBay and wasn't sure if it fits (even though seller says it will): http://www.ebay.com/itm/Bikers-Choic...990ea9&vxp=mtr
Old Jun 11, 2014 | 09:56 AM
4_stroke's Avatar
4_stroke
Have you checked the fuses for corrosion. There is one feed that permanently live and the fuse blades are prone to corrosion.
Old Jun 12, 2014 | 07:10 AM
Serenity Now
6th Gear
Anyone replaced their speedometer on carb Deuce and have a part number or know if this will plug and play fine: http://www.ebay.com/itm/Bikers-Choic...990ea9&vxp=mtr ?
Old Jun 12, 2014 | 09:43 AM
Harley_Dude's Avatar
Harley_Dude
You can use a 2000-2004 5" speed from any Softail or Road King. Plug and play.
nickatnightime
Nov 13, 2013 07:27 AM
baccalasports
Softail Parts
Apr 29, 2013 10:46 AM
soflafltri06
Electrical/Lighting/Alarm
Sep 11, 2012 07:20 AM
bigbaerdeuce
Jan 17, 2012 09:05 PM
baccalasports
Softail Parts
Aug 17, 2009 05:32 PM
