Breakout Kickstand
Old Aug 10, 2016 | 07:35 AM
  #51
cdonis's Avatar
cdonis
Originally Posted by EagleRay
Sorry to say but I don't have anything to complain about the kickstand on my Breakout. Works fine for me....no issues!
Sorry to hear about Mike. The kickstand is a little different on the breakout compared to most bikes.
Old Aug 10, 2016 | 04:05 PM
  #52
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
This for me too. When I kick it down, I ALWAYS give it an extra "nudge" with my heel, to make sure it's all the way forward.
Old Aug 10, 2016 | 11:15 PM
  #53
mdonohue's Avatar
mdonohue
I've just gotten used to it. The damned thing scared the crap out of me once or twice so I just make sure it's fully locked in place before I get off.
Old Aug 11, 2016 | 12:02 AM
  #54
EagleRay's Avatar
EagleRay
I found that before I lean the bike over on the kickstand I usually straighten out the bars/forks. As soon as the kickstand touches the ground I tilt the bars to the left which will make the bike move slightly backwards (0.5-1 in ). This movement pushes the jiffy all the way forward....that's become an automatism.
Old Aug 11, 2016 | 05:09 PM
  #55
FurryOne's Avatar
FurryOne
The point here is that you shouldn't have to do that. My last Harley never had kickstand problems. Harley redesigned the kickstand, and forgot the first rule of good engineering - if it ain't broke, don't fix it.
When the demo bike fell over on the stage in Daytona, somebody should have thought "Why did it fall over - operator error or mechanical problem?"
Old Aug 11, 2016 | 05:20 PM
  #56
harley0711's Avatar
harley0711
Can someonepost a 'Good' picture of this kickstand & the locking sys .. I would loce to see it
Old Aug 11, 2016 | 07:06 PM
  #57
HenryT's Avatar
HenryT
When I dismount the bike as stated in the operators manual I make sure the stand is fully down and the full weight of the bike is on the stand. This allows the stand to move into the locking notch.
Pulling on the bars or something while on the stand could cause the weight of the bike to shift off of the stand momentarily allowing it to release from the locking notch and the movement could cause the bike to shift forward. If its out of the notch when it creeps a bit forward it could at that time become unlocked. At that time its in a position to rotate rearward meaning it is not secured. Will probably fall over then.
Old Aug 11, 2016 | 08:10 PM
  #58
UHDhog's Avatar
UHDhog
Never had an issue with mine either. Even with it slammed.
Old Aug 12, 2016 | 06:24 AM
  #59
EagleRay's Avatar
EagleRay
Originally Posted by FurryOne
The point here is that you shouldn't have to do that. My last Harley never had kickstand problems. ...."
It's not that I have to think about it....just works naturally for me! And as I said, my Breakout has no kickstand problems at all!
Old Aug 12, 2016 | 07:15 PM
  #60
Dalt10's Avatar
Dalt10
I guess I've been lucky. Never had a problem and never thought about it.
