popping deuce
Old Aug 1, 2013 | 07:07 AM
robibnlr's Avatar
robibnlr
6th Gear
Default popping deuce
Hello all,
This is my first post, I have an 03' deuce with a stage one screening eagle air kit, Rinehart 2into2 pipes, a stage one HD download and the Vance and Hines fuelpak. Lately when shifting from 1st to 2nd, 2nd to3rd and so on, my bike pops. Exhaust is tight with no leaks air cleaner is clean. New plugs set at .40 gap. Any suggestions on where to look now? Its not bad just annoying. Thanks
Old Aug 1, 2013 | 08:15 AM
magna's Avatar
magna
You and half the guys on here, including me personally I don't mind it, makes the engine sound kinda rorty, heard big race cars doing the same, air leaks is one cause, other than that I think it can be tuned out if your bothered by it.
Old Aug 1, 2013 | 09:59 AM
magna's Avatar
magna
Having read your post again it is kind of unusual for popping to occur going up through the gears normally it happens going down, in my experience anyway, but same thing applies I should think it can be tuned out.
Old Aug 1, 2013 | 11:41 AM
Ramboamt's Avatar
Ramboamt
Originally Posted by robibnlr
Hello all,
The HD down load will still be a LEAN down load to pass EPA mandates. You can take it to a good tuner and have them retune the ECM to run a little richer which will eliminate, or reduce it considerably, the popping noise.
Old Aug 1, 2013 | 11:48 AM
oneballz's Avatar
oneballz
Mine pops too and untill I read all the crap on the forum about decell popping I thought it sounded cool.
After reading on hdforums, I still think it sounds cool.
Leave it alone and don't worry, it does no harm.
If you want it to sound smooth and quite go get a Gold wing.
I can say I ride at sea level, the last time I rented in Colo Springs the stock rental pinged missed and popped all week. Maybe its the air up there?
But if your performance is fine then leave it alone
glw165
Apr 27, 2015 10:39 PM
organhilbily
Aug 27, 2011 05:16 PM
organhilbily
Aug 27, 2011 05:04 PM
SweetPee
Aug 6, 2011 01:29 PM
cherrypewt
14
Jan 14, 2008 10:16 PM
