Go-Forward +2 kit for Slim - BINGO!
I'm 6'2", and was feeling a bit cramped up on the bike. I kept putting my heels on the very front corners of the boards, and riding over 100 miles was a stone bitch. My butt hurt, my jewels were numb, my back was aching, but I knew the bike could be changed.
My initial list was:
- to find a way to move the controls forward, which was initially looking to ditch the boards and put forwards on - probably around $1k, but then I found out about this kit, which I scored for $90.
- change the seat, probably Corbin or Mustang solo seat, $300-$500.
- add a mustache bar to put some highway pegs out there so I could stretch out for longer rides.
Install was really almost a joke. On the lift, unbolt three bolts per side, measure the distance between the jam nuts on the original shift linkage rod, remove the linkage rod, bolt the plates on to either side with supplied hardware, bolt the controls to the plates with 3 bolts each. Put the longer linkage rod back in at the initial measurement plus 2 inches, and tie-wrap the brake line back down. The wiring harness extension will take about 5 minutes to make, once I get those components, and about 30 seconds to install. The rubber bumper will be probably another 5 minutes... Whole process was probably an hour and a half, but I had to go back and forth for tools a few times...
The look of the bike really didn't change much, but I seem to have plenty of room, can now use the heel shifter, and all is good!
Initial estimate to get this result was about $1800. I'll have about $220 in it with a custom brake line, and I'm hoping I'll be set! I'm happy, wife's happy. Looks like the next mod might be affordable sooner than I had initially thought!
Before anyone calls me on it, yes, there are two bikes in the pics - the "before" are of the Lo, which is effectively the same bike for the parts we're looking at, and the "after", of course, are the Slim.
First two are profile photos to show how much forward the controls moved:
Brake side, before and after. In the after photo, you can see how the original brake line is kind of hanging out in space. I wasn't going to unbend bent tubing... :
Transmission side, before and after:
Kick stand, before and after. You can see how the ball and extension are almost resting on the cover - pain in the *** to deploy, and it could vibrate and rub on the face of the cover. This will be fixed first thing tomorrow morning. :
And an oblique view to kind of better show where the extension plate goes. The controls were moved 2 inches forward, and about 3/8 inch out due to thickness of the plates. :
I did go ahead and spec out a custom brake line, 'cause I'm just not too happy about the front line being exposed to potential damage and stress. It's just too critical a part to leave in this condition for very long. Hopefully within the next week or two, it'll be corrected.
... and, my butt isn't killing me after a bit of a ride, either. We'll see about a longer ride soon, and see just how much of a score this actually turned out to be, but I'm happy.
I did pick up a sheet of 1/8 thick hard rubber that I'll punch out a "coin" from and attach it to the bumper on the kickstand. Might have to go a couple of layers or even 3 to get the stand pushed out to a good distance from the primary, but this is an EASY fix.
Since I did this mod, there are more options that either came out or I became aware of. Some come with brake lines, some don't. The Drag Specialties catalog has a number of them listed. Either way, you have to replace the brake line. The OEM one can stretch, but the way the front banjo fitting and hard line is bent, it just doesn't fit well and looks like hell if you stretch it out.
Thanks for info.
