Installing Todds Cycle ape hangers - what all do a need ?
Installing Todds Cycle 12" ape hangers - what all do a need ?
I have the 12" Flat Black 0601-1468 which has the raised section between the clamping area and not sure that the riser with the top wide clamp, such as in the above picture, will work - I was looking at these on eBay.
What height risers would suit this installation ?
Also, what cable kit do you recommend (wire extenders, clutch, throttle, brake,......)
Riser height depends on taste, I think over 2" looks stupid. You can get a complete cable kit from lachoppers.com, search for your bike and bar height. You can get electric extensions from NAMZ, probably a 4" extension kit would be fine. That is all you need; bars, cables, electric extensions. Good luck.
I agree on the risers, and will will not use anything over 2", and now just need to find out if I can use the bridge type top clamp, or get the type with separate top clamps.
Thanks for the links on where to find the remainder of the goods.
