Made my own risers for my Breakout...LOVE THEM!
Old Sep 13, 2013 | 11:35 PM
Spazz's Avatar
Spazz
Default Made my own risers for my Breakout...LOVE THEM!
I had a little time and some 2" aluminum stock laying around and decided to go for it on the lathe.
Milled down to 1.75" diameter and cut at 1.75" length. Drilled out to 1/2"
Stock bolts are 2.75" long 1/2x13. Adding the 1.75" risers required 4.50" bolts.
I polished them out on a buffing wheel and installed them...
I can't believe the difference in comfort the risers made! (I wasn't uncomfortable to begin with, but sitting up a bit more made a world of difference)
The wiring to the speedo and blinkers only required cutting the zip-tie from the eyelets on each side of the tank rubber to relieve them.
I will have them chromed after a little detailing back on the lathe
Old Sep 14, 2013 | 12:07 AM
CanuckWhiskey14's Avatar
CanuckWhiskey14
that really made that much a difference for comfort ? I love the feel of my bike now but you have my attention on this ..... Wana make another set for some side $$$$
Old Sep 14, 2013 | 07:59 AM
Kiernans88's Avatar
Kiernans88
I have the same thing in 1.5" and it made a world of difference
Old Sep 14, 2013 | 08:30 AM
Spazz's Avatar
Spazz
Sounds too good to be true, doesn't it? It is hard to believe myself that this little adjustment makes this much of a difference.
As far as making more.... if I do... the polishing would be up to you....
Old Sep 14, 2013 | 08:50 AM
fcsallan's Avatar
fcsallan
Looks like a good solution. I would pull the bolts out occasionally to ensure there is not undue stress due to the added length. It's no fun to have a riser bolt snap on the highway........ yes I've been there.
Old Sep 14, 2013 | 03:59 PM
Spazz's Avatar
Spazz
Will do.... there were Grade 5's in there and put Grade 5's back in... I could always go Grade 8, but I think it's overkill.
Old Sep 14, 2013 | 06:08 PM
goats's Avatar
goats
i work with aluminum every day as part of my job, they hand us aluminum and tell us to make expensive custom pieces with basic tools.
you did a nice job making them!
Old Sep 14, 2013 | 06:31 PM
DEW2112's Avatar
DEW2112
I didn't like the HD solo luggage rack, so I made my own. I love making my own parts and no ones got one exactly like it! Nice job on the risers!
Attached Thumbnails Made my own risers for my Breakout...LOVE THEM!-100_2160.jpg
Old Sep 14, 2013 | 06:49 PM
Budmiester's Avatar
Budmiester
Good job and thanks for posting. Good to see some one else fabbing their own parts to solve a problem.
Old Sep 14, 2013 | 07:13 PM
Harleycruiser's Avatar
Harleycruiser
Very nice, yea small changes make big differences.
I went from two inch to four inch pull backs, love the difference.
