Headlamp Wiring
Old Oct 24, 2013 | 03:32 PM
Matt K's Avatar
Matt K
Originally Posted by xwhyz1959
Easiest thing to do, would be to get a volt meter, and see which leads are hot. Then switch to hi beam, and check again.
i have the bike disassembled at the moment, in order to do this, i need to have the ignition switched to on and test the 4 wires coming from the main harness, correct?
Old Oct 24, 2013 | 04:44 PM
xwhyz1959's Avatar
xwhyz1959
Yes. Make sure you don't let any bare wire ends ground out, or you'll be popping fuses.
Old Oct 24, 2013 | 05:43 PM
Harleycruiser's Avatar
Harleycruiser
Black is usally ground, so wire the two from the head light to black on the bike.
it is pretty common to have seperate ground to high and low.
Second the vom.
Old Oct 24, 2013 | 06:07 PM
Harleycruiser
The o/w is for a position light (whatever that is) on international bikes yea tape it off
Old Oct 24, 2013 | 09:47 PM
Matt K's Avatar
Matt K
i'm sorry guys. im a little confused. so I'll tape off the connection to the O/W wire. Then I'll plug white into white, yellow into yellow and black into black but then I'm left with a second black one.
How do I know which black one to plug into the plug and what do i do with the second black one that doesnt get plugged in?
Old Oct 25, 2013 | 05:02 AM
Harleycruiser
Second the vom.
Did you read this post?
Old Oct 25, 2013 | 04:21 PM
Matt K's Avatar
Matt K
I did. I just don't get it. So I splice the two black into the once black then white to white and yellow into yellow and leave o/w open?
Old Oct 25, 2013 | 05:24 PM
Harleycruiser
Yep,
To test take your light over to your battery and test it touch the yellow to + both black to - then check the white on +
That or you can use an ohm meter to check continuity.
Yellow black
White black
You should get a pretty high reading.
Old Oct 25, 2013 | 06:19 PM
Matt K's Avatar
Matt K
Yep,
Yellow black
White black
Excellent thank you
KingIan
Electrical/Lighting/Alarm
Jul 4, 2016 04:42 AM
Bruin08
Oct 15, 2014 05:01 PM
NKBIGN
Dec 16, 2009 04:41 PM
FrenchXD
Jan 25, 2008 04:11 AM
Fatboy2
General Topics/Tech Tips
Dec 18, 2005 08:40 AM
