Headlamp Wiring
Old Oct 22, 2013 | 05:00 PM
Matt K's Avatar
Matt K
Default Headlamp Wiring
I just bought a Drag Specialties headlamp to replace my stock headlamp. Laid the bike down and dented it up a little bit. So this new headlamp comes with 1 White wire, 1 Yellow wire and 2 Black wires. The stock headlamp has 1 Yellow, 1 White, and 1 Black.
The plug on the bike has 1 White, 1 Yellow, 1 Black, and 1 Orange/White. Can someone help me out here. First, with the new wires, I know to match up white and yellow to each other but which black one do I use?
And last, since the stock only had three, does that mean the Orange/white just never had anything plugged into it?
Pictures: 1st is the new wires in the Drag Specialties headlamp I got
2nd is the plug attached to the bike
3rd is the extra wire which I'm taping off cause I believe it just goes to the passing lamps which I don't use
Thanks for the help guys
Attached Thumbnails Headlamp Wiring-2013-10-22-14.44.35.jpg   Headlamp Wiring-2013-10-22-14.44.44.jpg   Headlamp Wiring-2013-10-22-14.45.07.jpg
Old Oct 22, 2013 | 09:57 PM
Matt K's Avatar
Matt K
anyone help me out?
Old Oct 23, 2013 | 10:40 AM
xwhyz1959's Avatar
xwhyz1959
What year and model bike?
Old Oct 23, 2013 | 10:51 AM
Alain's Avatar
Alain
I'm pretty new to the wiring aspect of the game myself but I can tell you what I would do. I would just try one black wire, if that didn't work I would replace it for the other black wire.
I replaced my own headlight by I don't have passing lamps on my rocker. It's not that big of a hassle to replace the black wires in the little plastic clip.
Good luck bud.
Old Oct 23, 2013 | 02:00 PM
Matt K's Avatar
Matt K
1999 fatboy
Old Oct 23, 2013 | 02:03 PM
Matt K's Avatar
Matt K
Good luck bud.
I couldn't get the wires out of the clip so I just got a new one. And I'm running the single headlight now with no passing lamps
Old Oct 23, 2013 | 04:38 PM
xwhyz1959's Avatar
xwhyz1959
Your black and yellow wires, should be your bright and dim leads.
Old Oct 23, 2013 | 06:32 PM
Matt K's Avatar
Matt K
yes, looking at the wiring diagram, the orange/white goes to the switches on the hand controls. if both black ones come from ground, should i match a black one up with the orange/white?
Old Oct 24, 2013 | 03:18 AM
Sweetglide08's Avatar
Sweetglide08
Damn I have it wrote down since I just did mine, I'll look if no body chimes in before then
Old Oct 24, 2013 | 06:28 AM
xwhyz1959's Avatar
xwhyz1959
Easiest thing to do, would be to get a volt meter, and see which leads are hot. Then switch to hi beam, and check again.
