HID Headlight Kits
Look at your weather proof connectors (on every connection) and if they have a locking tab on both sides of the female housing that means the male is reversible and I would try messing with those first which will be the same thing as changing the H4 socket spades only way easier.
Next problem... When I flip on the high beams it comes on and goes back to low beam as if i were flashing it. I'm charging the battery in case it's a low voltage issue, can't start the bike cause i don't have the tank back on yet
It wouldnt be voltage I dont think, there is an amp spike when the lamp ignites but after that it is stable with a draw less than halogen.
http://books.google.com/books?id=-kB...ically&f=false
My FI 05 has just the right amount of brains...do the AFR and leave the rest to me! ha
Before the HID lights, I started with the LED, but did not like the polka dot effect from the ones available at the time. Now there are LED bulbs using cree 1.5w SMD leds that get rid of that polka dot effect. Here is what I mean by the polka dot effect, brighter than the 55w standard bulb, can't really be seen too well with the eye, but very noticeable with the camera. OLD style LED is on the bottom -
I had purchased some LED's that use the cree for my passing lamps, and they blow away the new HID that was installed not too long ago. I am now waiting for the headlight led to arrive. Best part, they were about $15 shipped for the pair for the passing lamps Being LED lights, they use very little wattage, so there is less strain on the electrical system. The pics do not do them justice, as they are brighter than they show -
