Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jan 11, 2014 | 10:55 AM
  #111
EagleRay's Avatar
EagleRay
Default To lower or not to lower???
I'm thinking about having my scoot lowered by about 1 in. Actually I'm planning to get an airride this next fall/winter when the bike is in winter storage - need to save some §§§ first.
What do you guys think about lowering the stock height by appr. 1 in? Is it worth it - pros & cons. And which lowering kit would you recommend to do so?
Thanks for your ops!
Old Jan 11, 2014 | 06:44 PM
  #112
BroTim's Avatar
BroTim
I just got "Shotgun Shocks" installed which allow you to slam, lower, or put your bike at stock hight with the flip of a switch. 24v can tell you more about them since he's the one who told me and also I'm waiting to get my swingarm back so I haven't been able to try them out yet.
Old Jan 12, 2014 | 02:18 AM
  #113
Dwnlo's Avatar
Dwnlo
Originally Posted by Nostradamus74
Very interesting 24V. I saw that sprocket cover on HD site and for some reason for the first days they put the Catalog online this part was considered to fit BO. After a few days it has been canceled for BO.
I had the same doubt if this part could fit. Your assessment sounds correct. Just for curiosity, wider swingarm and mechanical differences on the rear end between BO and Blackline wouldn't affect the possibility to use this sprocket cover? I mean, stock sprocket with this cover would become inevitably a little bit wider, maybe touching some other mechanical part? I'm interested because sprocket cover and billet sprockets have a great difference in price....
Looks like it should fit.
In Australia the parts are even more expensive. So if sum1 knows more info I'd love 2 know lol
Old Jan 12, 2014 | 07:01 AM
  #114
BlessedHellride's Avatar
BlessedHellride
If I don't sell the Breakout I plan on going with the Dead Creek Cycles kit, it's like $75. I just can't justify the bill on shotguns, even though they are cool and provide convenience to adjust ride height. DCC's kit offers adjustability, but you gotsta get under the bike and wrench it. I figure if it's lowered 1 or 1.5, that's where it will stay.
Old Jan 12, 2014 | 07:14 AM
  #115
24v's Avatar
24v
Blessed, I'm sure you've read enough of these threads, but keep in mind that height adjustability is only one of the benefits of the ShotgunShock. Ride quality is greatly improved as well.
Old Jan 12, 2014 | 07:27 AM
  #116
BlessedHellride
yes, of course, I neglected to give props to that aspect. My spine and heart say "don't be a puss, get the shotgun"...my brain and wallet say otherwise right now. My first to do will be to take care of my current riser setup, though. I figure the DCC is the first option and if it doesn't pan out then move on from there.
What would be cool is a test ride...coming to NC any time soon? ha
Old Jan 12, 2014 | 07:29 AM
  #117
24v's Avatar
24v
I can definitely understand the budget aspect of it. Especially when you now have two bikes to mod.
As for the test ride, I'm sure there is someone with a Softail and a Shotgun that is much closer to you than me.
Old Jan 12, 2014 | 08:28 AM
  #118
EagleRay's Avatar
EagleRay
As I mentioned I'll sure be going with an airride in the long run. Unfortunately the Shotgun Shocks are not really an option in Germany as they are not considered street legal here (not technically certified). The system certified and available here is the Legend Airride L3/L9.
What I was curious about is what would be a good alternative to go with in the meantime until I saved up some $$$. Especially if I would only want to lower a static 1 or 1.5 in.
Old Jan 12, 2014 | 08:37 AM
  #119
24v's Avatar
24v
That all depends on your mechanical abilities. I think lowering bolts are the cheapest route if you can install them yourself. If you cannot, then the collars will be the cheapest because they don't require nearly as much labor. The ride will be the same with any lowering system that keeps the stock shocks. The lower you go, the stiffer you will need to adjust the shock to compensate.
Old Jan 12, 2014 | 08:49 AM
  #120
EagleRay's Avatar
EagleRay
As for warranty reasons there will not be any selfmade mods on the bike for the first 2 years. I wouldn't say that I don't care about labor $$$ but the kit needs to be of good quality not the cheapest. But it will only be a temporary solution for just one riding season.
I also will be riding 2-up every once in a while. Most of the time will be solo though.
BTW: What do you mean by collars...
