Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Oct 1, 2014 | 06:52 PM
  #1351
24v's Avatar
24v
Ok, I found something. Look here...
http://www.bikernet.com/pages/Processor_By_PM.aspx
"Having perfected mid controls, Roland integrated the shift side into the primary and created a unique right side drive hydraulic clutch master and brake control into one amazing aluminum structure. These would later become production parts and are now available from PM."
Still searching. JD said they were PM when asked later on that Insagram post.
http://instagram.com/p/iwWJI2lvu6/?modal=true
Old Oct 1, 2014 | 06:54 PM
  #1352
24v's Avatar
24v
http://www.viciouscycleworks.us/khxc...how/pm_mc.html
Old Oct 1, 2014 | 06:59 PM
  #1353
JimGnitecki's Avatar
JimGnitecki
Originally Posted by 24v
I have had no issues with mine. I ride the **** out of this bike. People who pay too much for something are usually quick to praise it in order to justify spending the extra dough.
Yes, but people who pay too little for something are usually also quick to praise it in order to justify spending less dough!
Jim G
Old Oct 1, 2014 | 07:30 PM
  #1354
24v's Avatar
24v
Jim G
You are so correct! No one buy a Dunlop 250, they suck and I have no idea what I am talking about.
BTW, I would LOVE to hear your first hand experience about either the Dunlop 250, or the Metz 260. Please enlighten us with your infinite wisdom.
Old Oct 1, 2014 | 07:35 PM
  #1355
JimGnitecki
Now, I never said that.
But I will say that when I replaced the stock Dunlop 240 on my Breakout with a Pirelli Diablo, which by the way is over 6 POUNDS lighter than the Dunlop, I rediscovered the joys of true HANDLING and NIMBLENESS.
Unfortunately, finding a non-Dunlop tire for the FRONT of the Breakout is proving to be a challenge, because of its unusual size. Yes, I could find a 120mm wide tire versus the 130mm wide, but I am reluctant to go narrower because I think it's the front tire's relatively wide width that diminishes the wide rear tire's normal tendency to resist turn-in.
Jim G
Old Oct 1, 2014 | 08:16 PM
  #1356
24v's Avatar
24v
So you have experience with the stock Dunlop. The Dunlop Elite 3 250/40/18 is a completely different tire from stock. I like it better than the stock tire as well.
Congratulations on your 6lb weight loss on a 700lb bike. I'm sure I removed more than that in crap that came from the factory. I know, sprung vs unsprung, blah blah.
If you want a tire that performs well, should last longer than stock, and fill the wheel well out better, buy the 250 Dunlop. If you are a weight weenie looking to squeak out that extra tenth around the track or hundredth of a mile per gallon in gas, go ahead and buy something else I guess.
Old Oct 1, 2014 | 08:53 PM
  #1357
jgos929's Avatar
jgos929
As much as I hate reading Jim's posts because the bulk of the time they're something negative about his bike and they just bring me down. I must say he has me sold on trying the Pirelli. No issues with my oem Dunlop yet but I'm only at 1200 miles on it
Old Oct 1, 2014 | 08:57 PM
  #1358
JimGnitecki
Wow 24V, it's not like you to be so stubborn. Don't take my word for it: Ask ANY high performance driver (car) or rider (motorcycle) about the immense impacts lighter weight tires have on both handling and nimbleness. It's like taking "cement overshoes" off a bike! While cruiser riders place proportionately more emphasis on appearance than other riders too, it's just plain silly to argue that a Dunlop 250 is a better PERFORMANCE solution. You do your reputation a disservice taking such a stance. Better that you simply say your top priority is appearance. I can understand that.
By the way, I hope you're not running at 250 tire at the HD recommendation of 42 psi for the stock 240. If so, you'll wear out the centerline long before you wear out the rest of the tire. I have confirmed that with the 240 Pirelli, 38.5 to 39 psi gives the right 10% psi rise from cold to hot, and the tread on the Pirelli is wearing much more evenly than the Dunlop was at 42 psi.
Jim G
Old Oct 1, 2014 | 09:01 PM
  #1359
24v's Avatar
24v
I never said the 250 Dunlop was better at anything than your tire. Go back and re read what I said. I'm not trying to make the absolute best handling bike. I completely understand how removing unsprung weight can help. The point is, this isn't a sport bike, it is a cruiser. If I want something that handles well I will ride my other bike. If I want to ride a badass cruiser I will ride my Breakout.
As for air pressure, you're preaching to the choir. I have been telling people to run less pressure in the back tire for quite a while now.
Old Oct 1, 2014 | 09:11 PM
  #1360
Alain's Avatar
Alain
You're good dude !!! Thanks for those links. That would be one freaking expensive mod!!!! Seeing Id have to use PMs primary and clutch housing if I'm reading that correctly.
I'd love to see that set up in person though.
