Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jul 10, 2015 | 09:32 AM
  #3381
dsalvi's Avatar
dsalvi
4th Gear
Default On the subject of bars...
Has anyone tried either Flanders 25 degree drag bars or wild 1 chubbys dragster bar on their breakout? If so thoughts and pics please...?
I want to keep the stock drag bar look. These two offerings advertise a pullback of 6"-6.5" inches. Which sounds like it would work but curious as to the aesthetics. Thanks for all replies!!
Old Jul 10, 2015 | 12:30 PM
  #3382
Frogprince's Avatar
Frogprince
Originally Posted by zz2h33
Is anyone running the reduced reach seat? If so how comfortable is it
My wife has been running this seat for a bit. Granted it was a pain to find one since they are back ordered.
Her compliant was that it was hard. Granted figure a 500 miles are needed to mold the seat. It is basically a stock seat with more foam on the back.
Old Jul 10, 2015 | 09:13 PM
  #3383
azrchrd's Avatar
azrchrd
I've been using the reduced-reach solo for two months now, love it. And I'm 6'2", approx. 215 pounds. I feel like the weight is distributed a little better, but I may eventually go with extended forward controls so I can stretch my legs out...
Old Jul 10, 2015 | 10:05 PM
  #3384
JimGnitecki's Avatar
JimGnitecki
I tried the factory Reach seat for several hundred miles, and ended up replacing it with an aftermarket seat.
The Reach seat does do what I wanted: it moved me forward, and that felt good.
But, it also moved me DOWN. That downward movement, coupled with the bike frame going UP as you move forward, reduces the amount of seat foam height available to cushion the rider from bumps. It was fine most of the time, but on sharp bumps, it hurt.
I finally went to a custom Corbin seat. I LOVE it. It provides real support, and I feel like I could ride a lot of miles per day on it.
Jim G
Old Jul 11, 2015 | 04:18 PM
  #3385
xkrspeedracer's Avatar
xkrspeedracer
Stage I
Default Drag bar stretch
First I'd like to say hello, I'm new here. I have read the entire breakout thread and have found it very helpful. I have owned 2 breakouts, a 13 and a 14. I traded up to get the hard candy chrome custom paint and abs. Now to my reason for this post. Like everyone else I had to reach too far forward and it was uncomfortable. After some research I had spacer Jims 1.5 inch spacers on my 13 but on my 14 I wanted more. So I went to a local machine shop and had some 3 inch spacers made. In the mean time I bought some adjustable riser extentions from Rox Speed Effects. They aalot of clearance 2 inches and they go in your risers in place of the bar and then the bar goes into them. They give a little bit of rise and pullback at the same time. The only downside is you have to reroute the wires that go through the hole in the triple tree and you have to turn the speedo 180 degrees in the riser cap along with the panel/strip with the neutral, turn signals, and high beam indicator. Then you can turn the whole cap 180 degrees so the speedo is now above the handle bars. Then when I received the 3 inch riser extentions I installed them under my original risers. Much better ride, seating position hasn't change but it feels much more comfortable. I had to loosen both banjo bolts on three front brake line to squeeze out all of the length of could get but it all worked. I went to the harley shop today and luckily they had a lot of clearence stuff on sale along with three boxes of brake lines. I found one that is 6 inches longer than mine and it was only 25 dollars. It is steel braided as well. Sorry for such a long post I'll try to download some pics as soon as I figure out how to do that. If anyone has any questions I'll do my best to explain the process. By the way total cost was under 200 dollars.
M
Old Jul 12, 2015 | 01:39 AM
  #3386
sothai's Avatar
sothai
Before I recently changed to the HD Beach Bars, I had a Danny Gray reduced Reach seat and it was very comfortable indeed. Looks-wise, it's a Butt Crack Solo style.
Once the Beach Bars were fitted, I went back to the stock seat.
HTH.
Old Jul 12, 2015 | 02:11 PM
  #3387
cdonis's Avatar
cdonis
M
id like to see pics. You may need more posts to meet the minimum before you can share pics.
Old Jul 12, 2015 | 04:53 PM
  #3388
financeman's Avatar
financeman
Thought i would post some pics of my breakout. Decided to clean up the front and rear of the bike. I removed the front turn signals all together and installed arlen ness deep cut grips and new levers. I really like how clean it looks up front now. I also ordered a bullet front light but i need to get a mount extension bracket for it before i can install it. If anyone knows where i can get one that is already powder coated black, let me know where and the part numbers.
For the back, i just removed the stock license plate bracket and installed a axle mount one i got off ebay. Looks great and no longer looks like i tumor off the backend of the bike.
Let me know what you guys think. I am eventually going to start my own thread so i can document my progress as i continually mod my bike. Thats part of the fun of owning a Harley right?
Attached Thumbnails The Everything Breakout Thread-20150712_171642.jpg   The Everything Breakout Thread-20150712_171654.jpg   The Everything Breakout Thread-20150712_171703.jpg
Old Jul 12, 2015 | 09:50 PM
  #3389
NSR's Avatar
NSR
Yeah, looks much cleaner without front signals.
What are you going to do about the uneven rear signals now?
...and what's going on with your passenger pegs?
Old Jul 12, 2015 | 11:10 PM
  #3390
financeman's Avatar
financeman
You have a really good eye.
I ordered the short bracket to go on the other side for the signals and that will even it out. When it gets in, it and the struts are off to get powder coated flat black.
I have the deep cut pegs i am installing on the front and rear. I just snapped the pic before i put them on. Lol
Guess i got a little excited.
