Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jul 8, 2015 | 11:54 AM
  #3361
LA_Dog's Avatar
LA_Dog
Originally Posted by zz2h33
Talking about the seat mount plugs, i just found out the other day that the rear pillion comes with a plug for the mount hole. Its located under the seat in a little holder. Its chrome though, but still looks better than an open hole. My first easter egg find on this bike haha
the second easter egg is the hot chick that magically appears on the back seat. LOL
Old Jul 8, 2015 | 01:07 PM
  #3362
Da-Rza 21's Avatar
Da-Rza 21
there should be two girls with the premium pricing we pay for these bikes!
Old Jul 8, 2015 | 01:11 PM
  #3363
LA_Dog's Avatar
LA_Dog
Nah that is reserved for CVO owners. with the regular BO you only get one hot chick, or maybe trade for two ugly ones.
Old Jul 8, 2015 | 01:22 PM
  #3364
Da-Rza 21's Avatar
Da-Rza 21
haha...forgot about the cvo package...
Old Jul 8, 2015 | 03:52 PM
  #3365
notch.johnson's Avatar
notch.johnson
Default CVO Hydraulic Clutch
I am interested in hydraulic clutch conversion using CVO 2014 parts. Sofar I identified these required parts:
Master cylinder and brake line
36700060B - master cylinder assembly (with lever)
37200021 - brake line
11348 - brake line o-ring
41747-82A - brake line banjo bolt
41731-01 - banjo bolt gasket (2 pcs)
Transmission housing
36805-06 - side cover gasket
25700178 - inner side cover
25700179 - outer side cover
37200023 - secondary clutch actuator
4705 - secondary clutch actuator screws (3 pcs)
Clutch
I assume at least a push rod needs to be replaced:
37000111 - rod with release plate (microfiche #19)
37092-06 - rod (microfiche #5)
37000113 - rod end (microfiche #21)
Unfortunately, I am not sure about other clutch parts (pressure plate #13, stopper plate #14 etc... or the whole clutch assembly #12?). Has anybody done this conversion already?
Old Jul 9, 2015 | 02:34 AM
  #3366
notch.johnson
After further digging I realized that CVO is using a different clutch (SE Assist & Slip Clutch, p/n 37000026). The question is if it is possible to use hydraulic actuator with FXSB standard clutch or if the whole clutch has to be replaced. Anybody can confirm?
Old Jul 9, 2015 | 02:40 AM
  #3367
LA_Dog's Avatar
LA_Dog
I don't think this is a conversion most would do. What's your reason for going hydraulic, stock cable clutch to hard to pull? there is always the drop-in variable pressure clutch.
Old Jul 9, 2015 | 06:18 AM
  #3368
24v's Avatar
24v
I don't know his reasoning, but I had considered a hydro clutch as it would be easier to route a hard line inside the bars if you are going for a smooth cable less look at the bars.
Old Jul 9, 2015 | 08:17 AM
  #3369
LA_Dog's Avatar
LA_Dog
hmm- that's good insight, makes sense. i take it you changed your mind though?
Old Jul 9, 2015 | 08:23 AM
  #3370
notch.johnson
There are several things I like:
- line routing options/cleaner look of the bars
- self adjusting
- smoothness
- no cable lubrication
- nice technology :-)
Of course there are also disadvantages. The variable pressure clutch is nice too.
