Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Mar 17, 2014 | 03:54 PM
  #391
legacywr's Avatar
legacywr
24v, I think yours is the best looking 'lightly modified' Breakout I have seen, but, I think you will ruin it with twin headlamps!
But, I'll have your Daymaker off of you!
Old Mar 17, 2014 | 05:23 PM
  #392
24v's Avatar
24v
Don't worry, I'm not selling the light I have now so if it looks like *** I can go back.
But also, don't think I'm just gonna bolt the factory Fatbob light on there and call it good, either.
If I do like it, my Daymaker bulb will end up on the wifes Sportster.
Old Mar 18, 2014 | 03:01 AM
  #393
Nostradamus74's Avatar
Nostradamus74
I was interested in the HD chin spoiler since it's small and would create a nice contrast with my chromed voltage regulator but...my 2014 BO has ABS and HD Parts Catalog says it won't fit ABS equipped models. As far as you know, what is the main issue? Any chance to bypass the problem?
Old Mar 18, 2014 | 03:19 AM
  #394
Nostradamus74
I'm talking about this one, p.n. 57040-08.
Old Mar 18, 2014 | 06:23 AM
  #395
24v's Avatar
24v
I've seen a few people ask that same question about ABS with the spoiler, but have yet to see anyone give a definitive answer. Might have to just buy one and try it out.
Old Mar 18, 2014 | 07:37 AM
  #396
Nostradamus74
I was worried to hear this answer...and if you (24V) don't have an answer for a technical question that means it's a tough one!
Old Mar 18, 2014 | 07:39 AM
  #397
24v's Avatar
24v
Wait a minute, just scrolled up. LOL
Isn't this a spoiler on a bike with abs?
Old Mar 18, 2014 | 07:45 AM
  #398
Nostradamus74
Yep, that's what reminded me of my question. I'd prefer the HD chin spoiler 'cause it has the hole for the voltage regulator. This one doesn't seem to have room for it (relocation?) or might be covered which to me is even worse for obvious overheating issues.
Old Mar 18, 2014 | 08:44 AM
  #399
cbaywolf's Avatar
cbaywolf
Originally Posted by JimGnitecki
Again let me clarify: The stock factory speedometer on the Breakout does NOT have that color change feature.
The available tach-speedo does, but you have to buy that and replace your stock speedo with it.
I have not checked, but I suppose it is possible that the CVO version (only) of the Breakout has that feature???
Jim G
Can anyone on here clarify- Is the proper way to get into Setup mode (to do these color adjustments) with the CVO speedo to hold down the "trip" button while turning the switch to "Accessory"?
I had my speedo replaced with the HD digital speedo before I ever brought it home, and can't for the life of me get it into setup mode (and I don't have the instructions that came with it). I've read somewhere that it's possible that there's a bent "accessory pin #6"- but that seems unlikely that one pin would be bent, as everything else on this unit works flawlessly (but it's possible)- so can you guys confirm that this is the correct way to get it into setup mode to adjust the colors?
It does go into some sort of "Diag" mode when I hold down "trip", and turn past ACCY to "ON" where all of the colors display for a few seconds...
Am I doing something wrong?
Old Mar 18, 2014 | 09:06 AM
  #400
Nostradamus74
Hope this may help. Anyway, just a tip, remember that you can download pdf files of the instructions you need of the HD parts on their site, simply going on the part you're interested in and clicking the "more info" option.
Attached Thumbnails The Everything Breakout Thread-hd1.jpg   The Everything Breakout Thread-hd2.jpg
