Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jan 13, 2017 | 02:23 PM
  #5331
JerzeyDevil's Avatar
JerzeyDevil
Winter is a good time for some changes. Currently waiting on a lot of what used to be chrome parts to come back from the powdercoater and when they're getting put on there will be a new gauge and some stuff from Performance Machine going on too:
What are you guys doing for options when it comes to a black dipstick cap? I haven't been able to find anything to replace the stock one with.
Old Jan 14, 2017 | 03:47 AM
  #5332
100thmonkey's Avatar
100thmonkey
The Stock one comes apart and get the powder coaters or spray shop to black it out then reassemble
Old Jan 14, 2017 | 03:33 PM
  #5333
EricRay's Avatar
EricRay
Put the custom Fly Screen on and really helps on those long rides! Easily comes off when riding local.
Old Jan 14, 2017 | 03:47 PM
  #5334
HenryT's Avatar
HenryT
Looks nice, I bet it does take some wind off the chest too. I have the 14" HD quick release shield for long trips that is a nice piece. But do like the BO most without a shield, so it only goes on if I'm doing +200 miles or so legs.
Old Jan 14, 2017 | 07:15 PM
  #5335
JerzeyDevil
So when I took things apart I missed labeling a wire on the right side under the tank and now I don't know where it goes. Anyone have an idea? It's the two wire plug with the black and white wires on the left side of the pic
Old Jan 15, 2017 | 06:45 PM
  #5336
tphykitt's Avatar
tphykitt
Originally Posted by JimGnitecki
When I put on the Pirelli, it was like the bike lost a set of concrete overshoes. The difference was THAT dramatic. Not only ois the profile better on the Pirelli Diablo, but it also weighs approximately 5 to 6 lb less than the Dunlop. That is no exaggeration - I compared the weights before I bought the Pirelli.
Jim G
what tire sizes are you running? what year is your breakout?
Old Jan 15, 2017 | 08:15 PM
  #5337
JimGnitecki's Avatar
JimGnitecki
My Breakout is a 2014.
Rear tire:
Pirelli Diablo
240/40ZR-18 79V part no. 1682600
Diameter = 25.75”
Weight = 15.55 lb (confirmed by Amazon shipping weight = 17 lb, and Jim G measured actual tire as 16 lb 0 oz. on 2 actual tires purchased)
$171 at Dennis Kirk, $170 at Amazon
$161 at Dennis Kirk on 2015-09-15
Rim used by Pirelli for measurements: 8.5”
Acceptable rim width: 8.0 to 9.0”
Diameter: 654mm = 25.75”
Acceptable tire psi: 36 to 42
Speed rating = 168 mph
Tread depth = 5.5mm = 0.2165”
Experimentally determined correct psi to get +10% rise when hot: 39 psi
Front tire:
TWO good choices:
Choice A:
Avon Front Cobra AV71 120/70V-21 Blackwall Tire - 90000000746
V-rated for speeds up to 149 mph
Tubeless blackwall
Sidewall ID Information: Avon AV71 Cobra 120/70/21 68V Reinforced
Dimensions:
Inflated Width/Measuring Rim Width: 4.7"/3.50
Inflated Diameter: 27.9"
Acceptable Rim Width(s): 2.75"-3.75"
Deepest Tread Depth: 5/32"
Balance Dot: None
Directional Arrow: Yes
Speed Rating:
V or V240-rated up to 149 MPCapacities and Construction:
Load Capacity/Inflation Pressure: 694 LBS/42 PSI
Load Range: C
Bias or Radial Ply: Bias
Tread Plies/Material: 4 nylon
Sidewall Plies/Material: 4 nylon
DOT Approved for Road Use: Yes
Tube or Tubeless: Either, depending on the rim
Aspect Ratio 70
Construction Bias
Position Front
Rim Size 21
Sidewall Blackwall
Speed Rating V
Tube Type Tubeless
Units Each
Width 120
Weight 10.55 lbs
$119 at JP
http://www.jpcycles.com/product/210-...um=retargeting
$125 at Dennis Kirk
https://www.denniskirk.com/avon/fron...prd/544055.sku
CHOICE B:
Avon Front AM41 Venom X 120/70H-21 68H Blackwall Tire - 90000000753
Dimensions:
Inflated Width/Measuring Rim Width: 4.7"/3.50"
Acceptable Rim Width: 3.00"-3.75"
Deepest Tread Depth: 7/32"
Width of White Stripes: Not applicable
Balance Dot: None
Speed Rating: H-rated for speeds up to 130 MPH
Load Capacity/Inflation Pressure: 654 lbs/ 42 PSI
Load Range: C
Sidewall plies/Material: 4 nylon
DOT approved for road use: Yes
Tube or tubeless: Tubeless
Aspect Ratio 70
Construction Bias
Position Front
Rim Size 21
Sidewall Blackwall
Speed Rating H
Tire Classification Cruiser/Touring
Tube Type Tube or Tubeless
Units Each
Width 120
Weight 10.6 lbs
$125 at JP, $131 at Dennis Kirk
I can't remember which of these Avon front tires I have on right now.
Jim G
Old Jan 16, 2017 | 02:15 PM
  #5338
UHDhog's Avatar
UHDhog
Pretty sure that's for heated grips. You shouldn't use that.
Old Jan 16, 2017 | 05:32 PM
  #5339
JerzeyDevil
Thanks! I was leaning towards that after looking at the service manual but hearing it from someone else makes me feel more sure about it and now I can keep moving along with getting everything back together.
Old Jan 19, 2017 | 01:22 PM
  #5340
tphykitt's Avatar
tphykitt
anyone have this on their breakout? think it would hold up just as well to a screaming eagle?
