Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Nov 16, 2019 | 03:49 PM
  #7101
HKMark23's Avatar
HKMark23
Originally Posted by cruisn
One minor issue I have with my bike is the turn radius. It seems like I'm frequently scraping pegs. Anyone know if an engine guard would reduce the turn radius even more?
Depends on what engine guard you buy. I've got this puppy:
https://www.lindbycustom.com/engine-...line-breakout/
You can see by its shape that road clearance is no issue. I've also done LA's recommended suspension mod. Do it !! You won't be sorry.
You can also slug the forks. I've extended mine by 2" but know that if you do this you'll also need to put a shoe on your jiffy stand or your BO will lean excessively when parked.
Old Nov 18, 2019 | 08:51 AM
  #7102
cruisn's Avatar
cruisn
That one looks sweet! Where did you get it from?
Old Nov 18, 2019 | 09:05 AM
  #7103
HKMark23's Avatar
HKMark23
Curse you for taxing the memory of an old man ! I think it was Dennis Kirk. I've bought a lot of stuff there over the years. If you go to the home page of the link I posted above, they probably have a list of Dealers. The Lindby line of engine guards is fairly common I think. Hope this helps.
Hmm, now that I think of it, I may just have bought it through that link.
Old Nov 18, 2019 | 10:54 AM
  #7104
LA_Dog's Avatar
LA_Dog
Very nice bud- good to see ya around. yeh don't slug the forks that will really suck doing that with the stock springs- lol - besides it's the same amount of work as dropping in new springs + ricor dampers.
Old Nov 18, 2019 | 11:48 AM
  #7105
cruisn's Avatar
cruisn
I didn't see the link in your post. But yea that looks to be the one!
Old Nov 19, 2019 | 08:34 PM
  #7106
Benjammin713's Avatar
Benjammin713
Originally Posted by RadarRat;[url=tel:16578072
16578072[/url]]
All this talk of new bikes is driving me nuts. H-D made a business decision. Personally I really like the direction they went with the Fat Boy and Fat Bob, the others are ok, and they fumbled with the Breakout. So to celebrate my awesome "old" Breakout, put about 230 miles on her today with a friend and rode to the top of Mt. Evans. Can't do that with a 3.5 gallon tank!
Took them up well above tree line. Bike pulled hard with its new SE 50 mm throttle body, 204 cams, and SE billet cam plate and oil pump. Stopped in Idaho Springs for lunch and a beer. Beautiful Colorado day.
does the 50mm throttle body fit stock 103 heads? I guess you’re happy with it?
Old Nov 20, 2019 | 01:15 PM
  #7107
LA_Dog's Avatar
LA_Dog
Yes- fits fine as do larger injectors. however, a tuner like the powervision (or dyno tune at a shop) is absolutely necessary to dial it in. Went with the andrews 48 cam on mine, fantastic. that cam puts the corrected compression ratio for the 103 in the sweet spot, does not require any head work, and it pulls like a train through the low to mid. Bottom line though, your largest performance gain over a stock breakout will come from changing the rear drive belt pulleys to 30/70 or 30/68. the difference is huge, even without any tuning. Cams, throttle body, tuning are smaller incremental improvements- but will give more benefit by having the belt pulleys done first. I'd even go as far as saying those who have done their belt pulleys won't want to bother with a cam upgrade, throttle body, etc.
here is the link to my past testing of andews cams on my 103 breakout. very useful. https://www.hdforums.com/forum/softa...t-softail.html - it will help show why some end up disappointed with the 57, 37 and some of the other off-the-shelf choices. it's all about the "DCR" - dynamic compression ratio- that you end up with - and that is dictated by cam events. It's imperative to know what your static compression is before selecting cam, and based on that along with the cam specs, will tell you what the cam is going to give as far as operational (dynamic) compression when the motor is operating.
Old Nov 21, 2019 | 09:10 AM
  #7108
cruisn's Avatar
cruisn
I just ordered a chrome oil tank for my bike. Anyone ever do an oil tank swap on the breakout? I have the manual and it seems like it's more complicated than I anticipated but I could def set some time aside to do it if need be.
Old Nov 21, 2019 | 12:01 PM
  #7109
jsmith800's Avatar
jsmith800
great question!! i'm pulling mine this winter to send to the chrome shop.
Old Nov 21, 2019 | 02:42 PM
  #7110
cruisn's Avatar
cruisn
I figured all that was needed was removal of the battery and the rear fender. Apparently you have to remove the rear wheel, and the splash guard as well. Then you need a special tool to remove the oil lines.
