Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jan 12, 2021 | 04:15 AM
  #7391
showin4fun's Avatar
showin4fun
Originally Posted by TCZ
Why did Harley ever put that ugly little gas tank on the Breakouts?
It just does not look right with all the space around the neck area.
But, that's just my opinion, maybe others like it.
Old Jan 13, 2021 | 11:43 AM
  #7392
TCZ's Avatar
TCZ
Different strokes for different folks. The looks don't bug me at all, but having to re-fuel so often does! Coming from a Road King the tank did look oddly small at first, but now that I am used to it I think it modernizes the bike, making it look longer and sleeker.
Old Jan 13, 2021 | 11:49 AM
  #7393
PC997's Avatar
PC997
Originally Posted by Hdbigblue
24 tooth and 54 tooth rear, and O ring X chain
Thanks.
Old Jan 13, 2021 | 11:52 AM
  #7394
MoneyFor's Avatar
MoneyFor
Exactly my thoughts, the view of the new Breakout is no longer as beautiful as the FXSB just because of that small tank, it is the same size as the FXBB. When I saw the FXSB Breakout I was immediately
sold, now I would not buy it or otherwise immediately do a tank swap with the Fat Boy or something.
Old Jan 13, 2021 | 08:29 PM
  #7395
vtchopperdude's Avatar
vtchopperdude
I'll start this post with "everybody likes different things, and THAT'S OK!!!" That being said, I am also not that keen on the 18+ Breakout frame, nor the smaller tank. Alot of what attracts me to the Breakout is the look of a rigid frame. The 18+ swingarm doesn't look like it's actually part of the frame. Having those smooth frame lines really makes the 13-17 Breakouts pop, IMHO. But, then again, I like choppers (if you couldn't tell by my screen name), so having a softail that LOOKS like a rigid chopper is my personal cup of tea.
Old Jan 14, 2021 | 04:14 AM
  #7396
showin4fun's Avatar
showin4fun
To me, this older style Breakout looks a lot lower and longer than the new models. The tank
fills in the front fork area and the top of the engine much better. Even the tank and seat flow
together better on the older models. The tank on the newer style Breakout make the bike look
more like a Sportster (taller and shorter length).
But, your right, there is a style for everybody. I just don't understand why Harley changed the
tank because the earlier Breakouts were just about perfect in style & lines.
Old Jan 14, 2021 | 04:18 AM
  #7397
MoneyFor's Avatar
MoneyFor
What I have to admit is that the M8 platforms are great in terms of handling, I now have 3 of them , FXBB, FXFBS and recently a FLFB but still like my FXSB the best in terms of the view and lines.
Old Jan 14, 2021 | 04:40 PM
  #7398
cruisn's Avatar
cruisn
Medford Dragstrip 2020. 130 Mph Quarter on pump gas
My version of what a Breakout should be. If it doesn't make horsepower it won't go on the bike. 107", PR3 Race flywheels with Timkin race bearings, Carrillo rods and Pistons at 10.25:1, Stage three port and polished and bathtubbed heads, 7/16 head studs, 570 blower cam, S&S lifters and pushrods, S&S High output oil pump and billet cam plate, Procharger B1 supercharger with 14 lb of boost ( roughly 20:1 at 14 lbs boost) 208hp 180 tq, at 6450 RPM, Drago's Dragula stepped exhaust,Screaming Eagle comp. sprocket, AIM lockup clutch, Baker Race Transmission with race shift ( nuetral is all the way down and gears are all up N123456.), Chain drive 24 and 54 rear. And yes I have a small backrest so I don't slide off the back.....lol
Badass. But something tells me it wouldn't wheelie without those decals.
Old Jan 14, 2021 | 05:32 PM
  #7399
showin4fun's Avatar
showin4fun
I have to admit, my opinion is a bit biased. I just don't like change.
Old Jan 17, 2021 | 04:17 AM
  #7400
Jessica Sinclair's Avatar
Jessica Sinclair
Could someone please message me with a link to service repair manual for a 2017 Harley breakout 103ci as well as a 2017 Harley breakout CVO 110ci engine
