Headlight's shaking all over the place
Old Mar 17, 2007 | 04:14 PM
06DEUCE's Avatar
06DEUCE
Default RE: Headlight's shaking all over the place
ok. here are some pic of the inside... not to good kinda blury. i also turned the chrome bracket that holds the light to the triple tree around, and moved the headlight out about 1"
[IMG]local://upfiles/4583/37793280D8964863A69B1102B9ACC8EF.jpg[/IMG]
[IMG]local://upfiles/4583/C20A5C882B2B413D8B4546086AA8B999.jpg[/IMG]
[IMG]local://upfiles/4583/F8C2275A469246B989E3BECBDE4C4350.jpg[/IMG]
Old Mar 17, 2007 | 06:11 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Thanks 06DEUCE,
It may not be the "best pic", but its enough to give me an idea of what's in there.
I like the idea of turning the mounting bracket around.
If you look at your sig pic as a before and the first one you posted.
You can see it hangs out there about 2 or 3" farther and makes the bike look a little "longer".
Very clever.[sm=goodidea.gif]
BTW If your camera has a little button on it marked like a little flower trythat kind of close pic after you push it. Its like an international symbol for a macro focus setting. It will resetthe camera's electronic auto focus system to allow it to focus properly on things closer than 2 feet away.
EDIT;
I noticed that you have the Bombay bars w/tach on your bike. How do they compare to the stock bars as far as where your hands and arms feel with them?
Old Mar 17, 2007 | 06:40 PM
TazInCT's Avatar
TazInCT
I thought the light shaked just to let you knowthe bikewas still running
Old Mar 18, 2007 | 03:58 PM
panamoncreel's Avatar
panamoncreel
Oh, sweet. Thanks for the gear needed tip and the inside pics. I'm going to definitely get to that. Once I'm done splattering my bike with bugs this weekend.
Old Mar 18, 2007 | 06:07 PM
BoneCrusher's Avatar
BoneCrusher
Thanks a lot man, nice work.
Old Mar 19, 2007 | 01:07 PM
NW FXSTS's Avatar
NW FXSTS
Just an observation from a safety standpoint.... That shaking light does get the attention of the oncoming cages...
Old Mar 26, 2007 | 07:33 AM
06DEUCE's Avatar
06DEUCE
i did my first night ride sincei fixed my headlight. this is a must do guys. replace the 2 front studs and leave the back alone. just enough flex to keep from shattering bulbs and no bouncing all over the place.
Old Mar 26, 2007 | 12:05 PM
BoneCrusher
Rode last night for the first time since I started this threadas well and I gotta tell you tightening the three bolts on the rubber studs made a WORLD of difference. While I am still going to do the 06DEUCE modthis will hold me over nicely till I do.
Old Mar 26, 2007 | 01:34 PM
06DEUCE's Avatar
06DEUCE
just a tip.. don't wrench on the stock studs to hard. they are glued together to much trq and you will snap the stud off the rubber. i learned the hard way...[:@]
Old Mar 26, 2007 | 09:03 PM
BoneCrusher
ORIGINAL: 06DEUCE
Good point. I was REALLY careful tightening those down.
