Breakout Wheels on my ROCKER
Old Jan 7, 2014 | 01:00 AM
  #41
m i k e's Avatar
m i k e
way lost LOL
lets see if i can get em started up again
just like the good ol day's LOL
Old Feb 4, 2014 | 11:53 PM
  #42
jtj75's Avatar
jtj75
Default Breakout trees
That is my crimson red bike Mike posted a pic of on the previous page, and I will give you a little insight on this project. The Breakout and Rocker share the same frame and that is about it. As I learned the hard way. The Breakout trees will hit the tank on your Rocker causing a dent and a scratch as the Harley shop did to mine. With that being said you have 3 options, 1-you can make or buy a stop to put in the neck to keep it from touching and you neck lock won't work. 2-you can purchase a set of HHI tees and wide glide axle kit(which is what I should have done!!!) this kit uses you same fork tubes. 3- do like me and change everything!!!! I had to put a Breakout Heartland kit, new gas tank, risers and handlebars. Just waiting on my paint to get done to reassemble. That pic of my bike was before I found this issue. The mechanic never saw it!!!! So good luck I hope this bit of info is helpful
Old Feb 4, 2014 | 11:54 PM
  #43
jtj75's Avatar
jtj75
Will post some pics of my bike when it is completed!!
Old Oct 3, 2019 | 11:59 PM
  #44
Graeme Dumbrell's Avatar
Graeme Dumbrell
Stage III
Originally Posted by rockinred
Why do you need to change out forks? You can mount wheels to your forks. I mounted breakout wheels to a springer front end.
Hub on Breakout wheel too wide to fit in.
Old Oct 4, 2019 | 07:37 AM
  #45
matte's Avatar
matte
6 years later, I'm hoping by now he has this sorted out. Holy necro batman!
v-rodder
May 25, 2017 04:00 PM
masar
Jul 31, 2014 01:22 PM
astranger1
Dec 29, 2013 06:59 PM
Bluemidnight
Jul 12, 2010 11:11 PM
fuzzyJ
Mar 6, 2009 07:37 AM
