turn signal relocation
Old Mar 19, 2007 | 12:48 PM
texfatboy's Avatar
texfatboy
Default turn signal relocation
i want to move my turnsignals from the handlebars on my 05 fatboy. i want to fit them to the side of the fork. has anyone done this. i cant find any kits for fatboy execpt for ones with a bar under headlight. i may try to make my own... any help will be appericated
Old Mar 19, 2007 | 12:57 PM
DickGrayson's Avatar
DickGrayson
Default RE: turn signal relocation
I relocated mine to my forks when I put on my short bars. The kit came from Harley. I'm actually taking them off right now. If you think they'd fit on yours, I'll sell 'em to you.
Old Mar 19, 2007 | 01:02 PM
OneBlackFly's Avatar
OneBlackFly
From my personal experience, don't splice the wires. Get new lamps (they come assembled w/ 36" leads). Splices are open invitations to shorts and water leaks.
I know that most riders don't like the lollipop lights on the bars, but pull up to a flat surface (a garage door), and you will notice that the lights on the bars are noticable. The lights on the forks can be drowned out by the headlamp.
Old Mar 19, 2007 | 02:25 PM
texfatboy's Avatar
texfatboy
thanks grayson. dont think they will work on a fatty. cause of the tins. but will do some research and see for sure thanks
Old Mar 19, 2007 | 06:44 PM
DR.Greenthumb's Avatar
DR.Greenthumb
Is this the look you're after?
If so it's easy to do.The bolt on the forks and the stock turn signal is the same size Just get a piece of all thread that matchesandcouple of chrome spacers.Screw the all thread into the forks,put the spacer on there then screw on the turn signal on.Use some loctite,solder the wires back together and you're good to go.
Old Mar 19, 2007 | 08:11 PM
markdt's Avatar
markdt
Great answer, looks awesome . I like the fact that they are not too low .. Mark...
Old Mar 19, 2007 | 08:15 PM
texfatboy's Avatar
texfatboy
thanks f.u.i.r.s. thats what i needed to know. and what i was going to try to do. i see yours looks great. thanks again
Old Mar 20, 2007 | 12:14 AM
kishstl's Avatar
kishstl
Great Idea. Looks good
Rick7938
Mar 16, 2011 09:43 PM
12mgs20
Electrical/Lighting/Alarm
Apr 22, 2009 08:56 PM
im1crazymf
Sep 3, 2008 11:15 PM
streeteagle
May 4, 2008 10:35 PM
texfatboy
Jan 20, 2007 09:03 PM
