SOFTAIL MINI BACKREST
Old Mar 20, 2007 | 05:52 AM
deadeye's Avatar
deadeye
Default SOFTAIL MINI BACKREST
Anybody have one of these under-seat mount backrests on a Softail?
http://cgi.ebay.com/ebaymotors/HARLE...92576238QQrdZ1
I like the looks of these better than a standard sissy with side plates.
Old Mar 20, 2007 | 10:42 AM
springerscott's Avatar
springerscott
Default RE: SOFTAIL MINI BACKREST
what would it take for this to fit a '99 Softail? I like the clean look of it.
Old Mar 20, 2007 | 12:42 PM
DyNaBoB's Avatar
DyNaBoB
WOW i gotta put that on the list, my brackets on my 06 bob cost that much.I need that for the train.
Old Mar 21, 2007 | 01:12 AM
XXXRacing's Avatar
XXXRacing
that one looks nice. I went with the plug and play on my bike:
Old Apr 11, 2007 | 11:10 AM
springerscott
I went ahead and purchased the backrest that was discussed at the beginning of this string. Happy to say that even though mine is a '99, this backrest for 2000 and up works. Only modification is the need to drill a hole and a notch for the supplied nut to come up through the fender, same thing that is already used forthe rear mount. So I ordered the pad when I realized this bracket will work.
Old Apr 11, 2007 | 11:19 AM
DyNaBoB's Avatar
DyNaBoB
hey XXX where did you get that set up?Did you paint it ?
Old Apr 11, 2007 | 11:27 AM
lionsqrne's Avatar
lionsqrne
Springer, how solid does it feel? Good and strong? I want one of these as well but have been hesitant as I wasn't sure how sturdy they might be??
Old Apr 11, 2007 | 11:42 AM
springerscott
It seems fine, the bracket and pad are not very tall so shouldn't be any leverage on the front mounting bolt. What I question is the thickness of the flat washer supplied in the kit, seems pretty thin. I may change that. If you get one, notice your seat bottom, might be a clearance problem for some seats, but there is plenty of slotted area on the bracket to drill the hole. I have the badlander seat.
Old Apr 11, 2007 | 01:52 PM
jimb's Avatar
jimb
I have that same set-up on my '02.
[IMG]local://upfiles/11733/1F02A131365746A88C9B1C441A82CEE8.jpg[/IMG]
Old Apr 11, 2007 | 01:56 PM
jimb's Avatar
jimb
Oh yeah, they have them for several different fenders, but since it mounts on top it should fit just about anything.I bought my fender from V-Twin and the sissy bar bracket is for a WCC fender.I believe you have to use a FX sissy bar though.It tells you not to use a sissy bar taller than 10".I figure that's a leverage thing.
[IMG]local://upfiles/11733/114C4E17BC3B4F84817F1C41E2319ADF.jpg[/IMG]
