Low fuel light
Old Mar 22, 2007 | 10:22 PM
Drtbag's Avatar
Drtbag
Default Low fuel light
On my 07 fatboy the low fuel light goes on when I fill the tank. and then will go out after the tank gets down to around 1/4.
What the hell is that about? anyone seen this?
Old Mar 22, 2007 | 10:35 PM
jhugs92's Avatar
jhugs92
Default RE: Low fuel light
simple, when it goes out, get gas.it's due to the strike.
Old Mar 22, 2007 | 10:42 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Do you have and LED fuel gauge. I was told if the grey wire isn't connected right the fuel light will run opposite.
Old Mar 22, 2007 | 11:25 PM
Drtbag's Avatar
Drtbag
ORIGINAL: HOGRIDA_06
Yes I do, But I followed the directions exact! I also installed one on the wifes bike with no problems.
Hmmmm, maybe I had a brain fart and crossed it. I'll have to check it out. Thanks for your response. It makes sense.
Old Mar 22, 2007 | 11:47 PM
rcmty's Avatar
rcmty
Hey Brtbag, I have a 07 Heritage and I installed a l.e.d gas gauge and I connectedmy grey wire to the wrong yellow & white wire and mine done the same thing your's is doing. You have two yellow & white wires under your console and if you connected to the wrong one it will show your low fuel light on when you fill up until you burn about 1/4 of your gas out then it goes off. Just connect to the yellow & white wire that runs to your speedometer and it will correct your fuel gauge. Now mine works fine after I re-connected to the right wire.
Hope this helps.
deeblues
Mar 4, 2021 02:14 PM
pte359
Jul 10, 2009 04:14 PM
tomato
Mar 24, 2008 12:07 PM
Larryc5079
Jan 14, 2008 12:31 PM
four5acp
May 20, 2006 08:04 PM
