Shovel Head Softtail
Old Mar 12, 2014 | 02:28 PM
forzen2510's Avatar
forzen2510
Stage I
Default Shovel Head Softtail
I have got a line on a 1990 softtail complete bike, but the motor is shot, as well as a rebuilt cone nose shovel. Besides shovel reliability and power, compared to an evo. If i wear to go threw with this swap how hard would it be and would it turn in to a money pit? I would like to keep the 5 speed and the stock primary, and later change to an BDL open belt kit. I have always wanted a shovel in a softtail frame. The shovel is a complete motor less a carb. Will the evo ignition and stock evo carb work on the shovel.
Thank You
Old Mar 12, 2014 | 05:12 PM
CSS_FXD's Avatar
CSS_FXD
From what I have heard a shovel and evo can be used in the same frame. But never done this personally. Check in the shovel head section too.
Old Mar 13, 2014 | 09:13 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Sounds like a really fun project. But I'm not sure how easy its going to be to fit a Shovel engine to an EVO primary/tranny setup.
You might try sending an e-mail to somebody like Baker transmissions.
They make transmissions for just about every Harley ever made and might be able to tell you for sure if they are compatible.
As for the ignition and carb it shouldn't be much of a problem to find off the shelf aftermarket parts that are not only better, but more reliable than original factory parts.
Even if they do come from an EVO.
Old Mar 13, 2014 | 11:12 PM
NDBadlands4-2's Avatar
NDBadlands4-2
Does sound like a good project, especially if you could get one with a kick starter. Very old school.
Old Mar 13, 2014 | 11:47 PM
DeJavu's Avatar
DeJavu
Thumbs up Bdl
Call Belt Drives Limited. I have their belt on my EVO chopper and I'm sure they have a setup for the 5 spd/Cone. Belts are also light and easy on bearings as well as being much simpler. The clutch has been trouble free and predictable. I've run on the drag strip and it performed flawlessly. I've got a kick only 4spd.
Old Mar 14, 2014 | 01:00 AM
The bike's tranny has an EVO 5 speed unit in it already.
So it would have to be retrofitted with a kicker door to get a kicker on it.
Would be very cool though, even if you never used it.
Old Mar 14, 2014 | 01:36 PM
DeJavu's Avatar
DeJavu
My buddy has an EVO softail and added the kicker for backup. He tours all over and hoped he never needed it. His trick was to stand on the kicker and pop the starter at the same time. It looked like he had Supermans leg!LOL!
Old Mar 14, 2014 | 05:02 PM
Tom84FXST's Avatar
Tom84FXST
Thank You
Pretty much a bolt in...5 speed and primary will bolt right up...ignition will work...carb will work but require re-jetting
Old Mar 18, 2014 | 09:17 AM
corliss@bakerdrivetrain.com's Avatar
and yes we do have a kicker kit should you choose to go that route.
Old Mar 4, 2023 | 12:37 PM
Hey Man's Avatar
Hey Man
A Shovelhead will drop right into an Evo frame but an Evo would require cutting and welding on a 4 speed Shovelhead frame. The Evo motor is taller.
randayn
Mar 15, 2012 07:30 AM
MikeCarenter
Engine Mechanical Topics
Oct 12, 2010 02:48 PM
ink n bones
Custom Models
Aug 30, 2008 05:00 PM
Vinnie85FXWG
EVO
26
Feb 18, 2008 12:07 PM
pharmboy
Exhaust System Topics
Jun 13, 2006 09:03 AM
