If it has a SERT, then the PO should have gotten it dynoed somewhere..
MAYBE you could find out where and they should have some record on it.
Son and I have had cams in our last 4 96'er and the only one you could really tell cams where done was the one's that he put in the SE 204's..
Your doesn't sound like it, but that was a short vid..
Another way is do a dyno run on it now.. If she's making 92-95 #'s of TQ,, then she's got cams...If she's in the mid 80's TQ then she just a Sgt1.. If she's 100TQ or so, then she's got cams and a Porting job...
Added,, the Numbers above is for a SAE dyno,, not a STD dyno run sheet. if its a STD then subtract 3-5 %
