2010, stock FLSTC backfire
Old Apr 11, 2014 | 10:04 AM
dawghouse127's Avatar
dawghouse127
Stage II
Default 2010, stock FLSTC backfire
hiya, I have a 2010 stock Heritage Classic..lately it is sluggish when starting.. and when I back off the throttle I get popping and backfires... there is no timing adj or such since its all electronic now..so is this a chip prob or any thing like that..?? any clues..?
Old Apr 11, 2014 | 11:26 AM
hdgzr's Avatar
hdgzr
Sluggish starting could indicate a ground or battery problem. You might check your battery voltage, loose cables, etc...
Old Apr 11, 2014 | 11:55 AM
Lucky McGruff's Avatar
Lucky McGruff
Are you using a fuel management system? If so you are running rich. I had the exact same problem, and I was running rich. Once I changed the afr it stopped immediately. I thought it was the battery because when I would try and start up my bike it would struggle to turn over like the battery was out of juice, but I soon realized that that along with the backfiring and popping I got on decel were connected.
carburetorjones
Jul 15, 2019 09:20 AM
jakedietz
Nov 2, 2018 06:07 AM
VRod02
May 1, 2013 09:10 PM
CT-Bagger
Mar 6, 2013 06:57 PM
Airborne350G
Mar 26, 2010 12:32 PM
