Reckless Fairing which mounting hardware?
Old May 13, 2014 | 09:12 PM
Shadowray's Avatar
Shadowray
I bought a Reckless Fairing for my 12 Deluxe but it didn't come with mounting hardware except for the mounting brackets that attach to the fairing. Also no instructions.
What mounting kit do I need to buy to make this quick on and off? Any help from someone with this same fairing?
Old May 14, 2014 | 05:47 PM
wils5150's Avatar
wils5150
mine came with metal grommets to replace the rubber grommets that the quick detach windshield uses
Old May 14, 2014 | 06:20 PM
Shadowray's Avatar
Shadowray
Thanks mine didn't come with metal grommets I guess they only come with those if you buy the fairing with the stereo and speakers installed?
Old May 14, 2014 | 06:37 PM
JustaHawg's Avatar
JustaHawg
Take the brackets to a dealer and see if they'll slide on Heritage rubber grommets. Heritage grommets should work but I don't know if the front panel on a Deluxe is pre-drilled to accept the grommet studs. Is there any kind of windshield hardware on your bike? If not you'll need to get or make brackets and fasten them to the side of the front panel.
Old May 15, 2014 | 10:43 AM
scottman50's Avatar
scottman50
I have one. Mounted right up to the factory windshield hardware.
Old May 15, 2014 | 11:01 AM
JustaHawg's Avatar
JustaHawg
That's what I thought, I didn't know if a Deluxe had the windshield hardware. The OP's hardware must be missing then. Either way - easy install.
EW1959
Aug 5, 2017 05:06 PM
XpEkt
May 14, 2017 07:54 PM
hd96heritage
Mar 15, 2014 07:40 PM
vitalidle
Audio Systems
Mar 13, 2014 06:53 PM
politronics
Jul 1, 2010 11:58 AM
