Harley Newb with clutch cable routing question
Old May 15, 2014 | 09:55 AM
Gbfan10's Avatar
Gbfan10
6th Gear
Default Harley Newb with clutch cable routing question
I put replacement bars on last night, but the clutch cable route doesn't look right. Is there another way to run that?
Old May 15, 2014 | 10:28 AM
hattitude's Avatar
hattitude
Mine goes from the lever, inside (aft) the bars, to the neck, and down the frame tube.
You have yours on the outside (forward) of the bars, then to frame tube.
My clutch cable hasn't been moved since OEM install.......
Hope that helps..
Old May 15, 2014 | 10:41 AM
heybaylor's Avatar
heybaylor
the best cable install is a straight line ..no bends. (impossible)
so the next best install is to have the least bend/bends in the cable as you can .
two big radius bends are better than one tight radius..
Whtwolf14
Nov 17, 2019 01:26 PM
PacBlue_07
Jun 9, 2019 11:25 AM
Hdbkstl
2018+ Softail Models
May 2, 2019 10:29 AM
cripple
Nov 17, 2012 05:44 AM
tna1000
Jul 25, 2007 09:26 PM
