Need Help!!! red key light on dash
Old May 20, 2014 | 10:31 AM
Papotobon's Avatar
Papotobon
2nd Gear
Default Need Help!!! red key light on dash
I usually just browse thru the post to get ideas, but now I would like to see if someone has had a similar issue or knows what might be going in with my lux. It's an 08 Deluxe I bought it used with 1 miles back in 2011 when I recently took it out for a ride after about a 1/2 he the red key light came on I then noticed my turn signals stopped working and when I turned the bike off it would start back up the light stayed on I don't have factory alarm I've never had a fob and bike just started doing this
Old May 20, 2014 | 01:42 PM
nevil's Avatar
nevil
The light means your bike threw a code. You should check for them, but try disconnecting the battery for a few minutes to clear any codes:
https://www.hdforums.com/forum/ignit...tic-codes.html
Old May 20, 2014 | 02:00 PM
mtiberio's Avatar
mtiberio
happened on my bike when the fat rear tire wiped out the directional wires. and they either shorted together or to the fender/ground. Once I isolated the bare wires, I fixed the insulation, and rerouted them to avoid any issue in the future. On my bike (2002 FB), it has a 140 rear, and is very tight on the left side of the fender...
Old May 20, 2014 | 02:19 PM
Papotobon's Avatar
Papotobon
2nd Gear
Nevil appreciate the link will try to see what code shows up
Old May 20, 2014 | 02:23 PM
Papotobon's Avatar
Papotobon
2nd Gear
Mtiberio I do have Shotgun Shock I'll check up under rear fender to see if any wires are exposed
Old May 21, 2014 | 04:29 PM
fourhour's Avatar
fourhour
I had a loose battery connection cause the red key to illuminate.
Old May 21, 2014 | 09:05 PM
spydyr's Avatar
spydyr
My wife's heritage has been having similar problems. The red light will go on (she does have security) then the headlight & nacelle lights will go out, the turn signals won't work or self-cancel, or, yes I said OR, the radio will stop working for about 2-10 minutes. I was leaning towards the BCM since it controls the electrics & it seemed so sporadic. Dealer says they replaced the voltage regulator and all fixed now. We'll see!!!
Old May 23, 2014 | 06:26 AM
mtiberio's Avatar
mtiberio
So, how did it look?
OldHippy
Oct 14, 2018 07:43 PM
Buckscent
May 22, 2016 05:48 PM
delrey737
Apr 16, 2016 07:21 AM
Blueflame1
May 31, 2013 02:18 AM
B-Duff
May 8, 2011 04:58 PM
