Engine Head Temp Sensor
Old May 21, 2014 | 06:08 PM
jmr1971's Avatar
jmr1971
Default Engine Head Temp Sensor
Anyone have a link to a site I can buy this part for a 2004 FLSTCI and also a link to a video to show how to install?
Old May 21, 2014 | 07:00 PM
Misbehaven's Avatar
Misbehaven
You can find you part number and order it from here.
Also you can see an explode view of where it goes.
http://www.shopronniesharleydavidson...partfinder.htm
Old May 22, 2014 | 05:21 PM
olongapo1's Avatar
olongapo1
Just had to replace mine about a month ago. The Engine Temp Sensor is located at the rear of the front cylinder. Access it from the left side of the bike. There is a little trick to getting it in and out. You must use a deep well socket to clear the electrical connection on top of the sensor however the overall length of the deep well socket and attached ratchet will make contact with the rear cylinder. Use a hack saw and cut 1 inch off the end of the socket. The socket and ratchet will then easily fit between the cylinders. This is an easy replacement item once you have the correct length socket.
ReverendBell
General Topics/Tech Tips
Oct 3, 2017 05:58 PM
glsec507
May 16, 2017 02:49 PM
natedog_37
Aug 30, 2016 11:44 AM
adm
Apr 20, 2016 11:49 PM
jmr1971
Engine Mechanical Topics
May 24, 2014 09:11 PM
