how to trailer it
Old Jun 24, 2014 | 07:50 AM
  #51
pat.h's Avatar
pat.h
Hahahaha!
Old Jun 24, 2014 | 08:26 AM
  #52
ynots's Avatar
ynots
I use a wheel chock and go around the rim with a strap that holds it in tight. Then I run ratchet straps around the lower tree to mounting rings that are angled forward and to each side. I only compress the forks about 50%. When I sit on the bike and push down & forward on the bars I like to see the forks compress about an inch without using a herculean effort. I then fasten a bungee's between the hooks on the ratchet so they cant shake loose in case I hit a pothole. I also use 2 straps on the back that pull to each side.
Old Jun 24, 2014 | 08:59 AM
  #53
1BRAVO9's Avatar
1BRAVO9
Originally Posted by Tom84FXST
I am a RUB poser...I petend to be a rich urban biker...
I'll give you pass though, being you are from Mississippi.
wrongway2
11
Aug 29, 2010 05:54 AM
rooster3171
Mar 26, 2010 07:50 AM
leeinmemphis
Nov 11, 2008 01:30 PM
intruder
Jan 24, 2008 03:10 PM
Fineultra
Jun 11, 2007 05:55 PM
