Need help with progressive drop in fork spring install
Old Jul 7, 2014 | 09:14 AM
Longshot USMC's Avatar
Longshot USMC
6th Gear
Default Need help with progressive drop in fork spring install
Hey guys, I'm a pretty handy guy but this is my first move into turning wrenches on my Harley. I wanted to give the bike an altitude adjustment and while the rear shocks seem pretty straight forward, installing my drop in fork springs seems to have me a bit held up. My bike is a 2002 softail standard, I remove the fork caps and I can't figure out where to go from there. There's threaded holes inside... really thought this was going to be straight forward but I'm hung up and not sure what to do. The service manual wasn't very much help either.
Old Jul 7, 2014 | 09:29 AM
Ramboamt's Avatar
Ramboamt
The Progressive instructions are pretty good. When you remove the top fork cap you will need a LARGE good quality adjustable wrench to catch the flats that are on the base of the internal threaded insert that the caps screwed into. Do you have the forks out of the steering head?
This does make it easier to install the Mono-Tube shocks, if that is what you are installing. Here is a video from google on the install of the Mono-Tube:
Hope this helps.
Old Jul 7, 2014 | 11:09 AM
QC's Avatar
QC
It isn't as "drop in" as it seems. You're going to have to remove the fork tubes from the triple tree. Then the large cap with the 2 flats on it can come off. Then the springs can come out. There are youtube videos for this. It isn't really complicated and I was very intimidated the first time I did it, but is pretty straight forward. Just hard to describe in a post.
cHarley
Dec 31, 2023 01:56 PM
Badgoat
General Topics/Tech Tips
Sep 7, 2018 09:01 PM
Longshot USMC
Jul 11, 2014 06:03 AM
TexFF
Jun 3, 2013 11:56 AM
Ncdyna925
Apr 9, 2013 01:18 AM
