Error Code Help
Old Jul 8, 2014 | 10:24 PM
Buckley29's Avatar
Buckley29
Default Error Code Help
Hey everyone. I recently purchased my first Harley (2011 FLSTFB). The bike has just under 5,000 miles.
Riding it home I noticed a blinking red light which I later learned was an indicator that a code is being stored.
The bike seems to run great, except when its dark out I notice that every now and then the speedo light will shut off for a few seconds.
I got into the diagnostics menu and had three options:
BCM: N
ECM: Y
SPD: Y
When I went into either the ECM menu or SPD menu, I got the code 62272.
Anyone know what this error code correlates to? My suspicion is that the voltage regulator is on its way out based on the symptoms...
Thanks guys,
Mark
Old Jul 9, 2014 | 12:33 AM
WildBill2566's Avatar
WildBill2566
I thought all the error codes commenced with a letter.
I think it's something to do with the speedo settings, I know with the software I have I can change the speedo settings. It could be the speedometer's pulses per unit value displayed. This number will vary depending on how it is set up. This will depend on things like wheel size fitted. So in your case the speedo sender unit sends 62272 pulses which equals a mile.
I don't think the value you describe is an error code.
That's my best guess.
Old Sep 4, 2014 | 10:40 PM
Michael Sowers's Avatar
Michael Sowers
Stage III
Default code 62272
I have the same issue and code (62272) Did you get it figured out?
Old Sep 5, 2014 | 10:08 AM
jam436's Avatar
jam436
First of all, WildBill is correct.
That first digit isn't a 6, it's a "b"
According to this chart I found:
http://www.passion-harley.fr/mecanic...ode-erreur.pdf
b2272 means "BCM or Speedometer voltage high"... so you may already be on the right track thinking it's the voltage regulator...
Old Apr 3, 2019 | 09:24 AM
Jeremy Roberts's Avatar
Jeremy Roberts
Stage I
Default Clarification.
Thanks for the clarification on the its a b not 6. Makes everything make sense.
RosevilleRiding
Jun 2, 2018 08:47 PM
chriswillrise
Nov 13, 2016 04:27 PM
Joemark73
Jun 4, 2016 04:33 PM
sinolav
Electrical/Lighting/Alarm
Jul 16, 2015 07:31 PM
Junior_co
Oct 3, 2012 07:32 AM
