Suspension issue - need guidance
Old Jul 28, 2014 | 03:49 PM
hattitude's Avatar
hattitude
Originally Posted by Branner
The answer to your question is simple, buy this jacket and all will be well...........
Old Jul 28, 2014 | 04:14 PM
JimGnitecki's Avatar
JimGnitecki
Damn, I never put it together! I was wearing that jacket on both those rides, so is THAT what made the ride so much less jarring on the really bad bumps???
Gosh, it makes sense - that jacket leather is sooooo soft . . . .
And those vertical braids on the sides would definitely soak up road ridges!
Jim G
Old Jul 28, 2014 | 04:39 PM
tbonetony06's Avatar
tbonetony06
The air pressure in your tires are not for or based on the comfort of your ride. The given tire pressure is tested and based on the type of tire it is, how it is made and what it is being used for. Given that information the tire pressure is critical for how the tire handles, wears and most important for SAFETY!
I would not recommend running on incorrectly inflated tires trying to adjust your "suspension". In my 40+ years of riding I have seen guys do some crazy things over the years, including myself, trying to do this, that or the other and cut corners or to save a few pennies trying to accomplish something. I learned long ago to just do it right, address what need's addressed even if it meant putting up with something until I could afford to do it right AND most of all to NEVER do anything that would compromise the stability and safety of the bike. Tire pressure is CRITICAL!!!
Old Jul 28, 2014 | 05:10 PM
MicahB339's Avatar
MicahB339
Have you considered a shotgun shock??
Sorry I couldn't resist lol
Old Jul 28, 2014 | 06:12 PM
JimGnitecki
You are forgetting that 41 psi is the maximum psi that Dunlop says that tire cn accept. That's also the setting that HD recommends for a SOLO rider. Does this not sound erroneous to you?
Jim G
Old Jul 28, 2014 | 06:41 PM
JimGnitecki
I just rechecked my numbers, and it's even a bit worse than I thought.
HD actually recommends 42 psi for the Breakout, and that's the ONLY psi they give (no recommended psi increase for a passenger).
But Dunlop, who builds the darn tire, rate the tire for a MAXIMUM pressure of 41 psi, not 42, and says the tire can carry 963 lb at that psi.
So what gives with the HD recommended psi???
Jim G
Old Jul 28, 2014 | 06:53 PM
24v's Avatar
24v
I run 33-35 psi in my rear tire. This gives me great handling and contact patch, and evens the wear a little bit.
Also Jim, the Breakout is 710lbs wet according to Harley.
If you are having issues in pavement changes lift your *** off the seat for that split second. Wont cost you a penny.
Old Jul 28, 2014 | 06:59 PM
JimGnitecki
Yeah, you are correct with the 710 pounds.
I WOULD lift my butt on ridges, BUT:
1. I often can't see the ridge before I hit it (that's how small those ridges are that causing the jarring)
2. With the forward peg position on the Breakout, it is mechanically extremely difficult or impossible to lift yourself out of the saddle while underway. On a bike that has mid controls, sure, that is what I would be doing.
Jim G
Old Jul 28, 2014 | 07:08 PM
24v's Avatar
24v
Jim G
1) Look farther ahead.
2) Do more squats.
I ride my bike with very little travel most of the time so I have practiced. I do not have any trouble getting my butt off the seat for a bump.
Old Jul 28, 2014 | 10:21 PM
hattitude's Avatar
hattitude
Jim G
Damn, you crack me up..... good sense of humor
As far as your suspension goes, I would have to agree with tbonetony06. I think you need keep your tires properly inflated, and work on the suspension to get the ride right...
Good luck..
370H55V
Jul 29, 2013 01:06 PM
Smokengun
Jan 31, 2013 07:43 AM
vl1500
Sep 12, 2010 08:21 PM
JimmieJack
Mar 26, 2010 01:23 AM
easy4me
Aug 18, 2009 08:32 AM
