Speedo and odometer cutting out
Old Aug 24, 2014 | 11:54 AM
JayWatkins's Avatar
JayWatkins
Default Speedo and odometer cutting out
When I'm riding along my speedo and odometer will just cut out. If i pull in the clutch it will come back on and then when I let out and start going again it will cut out again after a minute or 2. It's a 99 softail standard. It just started doing it today and I washed it yesterday.
Old Aug 24, 2014 | 01:10 PM
osuhd's Avatar
osuhd
Check battery connections, that was my issue on a street Bob
Old Aug 24, 2014 | 03:17 PM
JayWatkins's Avatar
JayWatkins
Any other options. I tightened it down but it's still going in and out
Old Aug 24, 2014 | 05:17 PM
spydyr's Avatar
spydyr
Vehicle Speed Sensor (VSS), mounts on top of the tranny, was the issue when mine was doing that around 80K.
Old Aug 24, 2014 | 06:18 PM
JayWatkins's Avatar
JayWatkins
SPYDYR Was your bike doing the same thing?
It seems like it's the vibration doing it, cuz if I don't let it rev up to much between shifts it doesn't cut out
Old Aug 25, 2014 | 06:22 AM
JayWatkins's Avatar
JayWatkins
Bump for help
Old Aug 25, 2014 | 08:12 AM
spydyr's Avatar
spydyr
Mine wasn't cutting in and out, but usually would after about 20 minutes or so (once it got warm?), I'd be idling at a red light, and I'd take off and it wouldn't register anything. If I turned the bike off and on again, sometimes it would start working again, sometimes not. But once it cut out, it *might* come back on after maybe 30-60 minutes on the same ride.
The odometer is of course connected to your speedometer. If you go at zero speed, there's no mileage to track.
Old Aug 25, 2014 | 08:23 AM
spydyr's Avatar
spydyr
One thing you could try, is to take out the VSS and clean it off real good. It's basically a magnetic sensor, and when I pulled mine out, it looked like it was a drain plug, covered in tiny metal bits over the years/miles.
That way, you'd be doing some good diagnostics without spending any money on parts you might not need. If you clean it, they say it'll last a little while longer. The best of course is to replace it, but if you're iffy on whether its that or not, it's an option. Just throwing it out there.
Old Aug 25, 2014 | 06:52 PM
JayWatkins's Avatar
JayWatkins
Thanks spydyr I'll give it a try tomorrow after work. It's to hot outside to mess with it today. It's 7:53 pm and 90 degrees out with 100% humidity
Old Aug 25, 2014 | 07:09 PM
JayWatkins's Avatar
JayWatkins
SPYDYR is yours a FXST? Where is the vss located on a 99 FXST? I can't find it in my manuel.
Is it hard to get to? I'm a novice at working on bikes
