Wrinkle/texture black.
Old Apr 9, 2007 | 02:27 PM
janne63's Avatar
janne63
Default Wrinkle/texture black.
What is that paint on 2006 Night Trains struts and oiltank?
Is it wrinkle black or texture black?
Old Apr 9, 2007 | 02:45 PM
twowheelsforever's Avatar
twowheelsforever
Default RE: Wrinkle/texture black.
It's actually wrinkle black powdercoating.
Old Apr 9, 2007 | 03:44 PM
janne63's Avatar
janne63
I need to paint new sissy to that same colour and HD have both on spray paint.So I rigth one is wrinkle black?
Old Apr 9, 2007 | 04:04 PM
twowheelsforever
I've never used the spray paint, but I've had some stuff powdercoated with the wrinkle black powder and it's an exact match. You may not get the same look with the spray can, but hopefully it will be close.
Old Apr 9, 2007 | 04:10 PM
janne63's Avatar
janne63
Yes I know that.Spray paints are no good...but I have no place to get it powdercoated so I hope to get as close original look as possible.
Old Apr 9, 2007 | 04:45 PM
twowheelsforever
If you need a good powdercoater, try:
http://www.eastcoastpowdercoat.net/
They've done a bunch of stuff for me in the past and do great work. They'll do shipping both ways, and they've got customers all over the country...
Otherwise, good luck with the spray paint. If the prep is done right, you should be able to get a decent finished product with the spray.
Old Apr 9, 2007 | 05:56 PM
cwsharp's Avatar
cwsharp
I ordered a can of the spray paint from Harley... to fix a small area on my primary cover. HD calls it 'texture black' I am pretty sure. I cleaned the engine area that I was going to paint with lacquer thinner then sprayed away using a mask to fog the edges. You can't tell it was painted.
There is a product from S100 that makes the old texture black finish look brand new...
C#
Old Apr 9, 2007 | 11:08 PM
davzdorado's Avatar
davzdorado
I've been tossing around the idea of getting my tins done in Line-X
Any thougts ???
Old Apr 10, 2007 | 01:53 AM
agapsdiver's Avatar
agapsdiver
Default RE: Picture here of Wrinkle Finish.
There is Texture Black spray (pn 98606BF) and Black Wrinkle Finish spray (pn 98606CJ)
The oil tank, engine block of the Night Train is Black Wrinkle Finish.
I tried it on a couple of access. boxes, worked on one, not
the other. Be sure the outside Temp. is correct and not much humidity.
If you just need a touch up I would us theTexture Black spray and not worry about the Wrinkle.
[IMG]local://upfiles/6335/77D99FCFA953443AB89DD359E2D70ED7.jpg[/IMG]
Old Apr 10, 2007 | 04:36 AM
flst06's Avatar
flst06
Have not used the textured HD paint but have had much success with other brands of spray can textured paints. Follow the directions and most importantly make sure you follow the temperature recommendations. The brands I've used did not texture completely if it was too cold.
The only thing worse than trying to achieve perfection with a spray can is trying to do it twice.
Don
