New Screamin' Eagle Street Legal 110 Cubic Inch Stage 1 Kit for EFI models (see below for fitment). This kit is brand new and has only been out of the box for pictures. You will be receiving everything that is shown in the pictures. Your cases will have to be bored to fit these cylinders.
Bring your Twin Cam motorcycle up to the same displacement and power output as the CVO Screamin' Eagle models - a whopping 1800cc's. This 50-state street legal kit combines all the proven component of the '07 Screamin' Eagle models - the 4" big-bore cast pistons and cylinders, SE-255 camshafts, and cylinder heads with automatic compression release. The Screamin' Eagle cylinder heads and cast piston combination offer a 9.3:1 compression ratio for easy starting. The cylinder heads also prominently feature the "Screamin' Eagle" script. Kits include all required gaskets (except primary cover) and hardware to complete the installation. EO pending for '07 models. All models require ECM recalibration. I will also include the wiring harness for the compression release, which would normally need to be purchased separately.
Part number 29912-07.
Appears that this will fit (according to screaming eagle book for 110 kit) 07 later Dyna, Softail, and Touring models. Also fits 99-06 Twin Cam models equipped with 4 5/8" stroker flywheels.
Thanks, Randy
$850 shipped (Retails for $2800)
Reason: SOLD
