engine cuts
Old Dec 5, 2014 | 01:04 PM
kally's Avatar
kally
2nd Gear
Default engine cuts
Hi there, when I try to start the bike(2008 sporty 883) it runs for a few seconds and then cuts. I am getting some strange fault codes: 51 dE st stAND or something like that, the trouble is they wiz by so quick they are hard to read, all help appreciated, Kally
Old Dec 6, 2014 | 02:34 PM
Pixiechitos's Avatar
Pixiechitos
It's your side stand sensor giving an error. No experience with this though.
Old Dec 6, 2014 | 04:30 PM
kally's Avatar
kally
2nd Gear
many thanks will give it a once over, regards Kally
Old Dec 6, 2014 | 10:48 PM
elfnyc's Avatar
elfnyc
if u sit on the bike and put up the jiffy stand does it starts up normally. If u pull the clutch lever in does it seem to start up normally ?
check your battery terminals are clean and tight
also check the ground to the bike clean an tight
clear the codes
see if that works
if not
what u can do
1 check the connections at the the Jiffy stand switch clean and greased
2 change the switch if faulty
Old Dec 7, 2014 | 08:02 AM
kally's Avatar
kally
2nd Gear
working at the mo but will try your suggestions when I get home, many thanks, Kally
Old Dec 8, 2014 | 12:39 PM
kally's Avatar
kally
2nd Gear
Default engine cuts
Got it started today. Cleared the codes and started it with the jiffy stand up. Was ok for a while and the codes came back. Read on another forum that a low battery can cause this? Battery was low so am charging it at the mo, regards for help, Kally.
Old Dec 8, 2014 | 05:07 PM
elfnyc's Avatar
elfnyc
yeah a low battery charge will also make that happen
Old Dec 16, 2014 | 03:36 PM
kally's Avatar
kally
2nd Gear
Smile
New battery has sorted this problem completely. Ł53 Motorbat, with more power that the normal Harley Battery. Should be good for some time as I have also bought a new tender to hook it up to when not riding, regards to all Kally
my sporty
Old Dec 27, 2014 | 07:32 PM
elfnyc's Avatar
elfnyc
glad to hear --
nice ride ,very sharp
and the motobat will be good for looong time
and its covered for 2 yrs
Old Dec 28, 2014 | 10:55 PM
phelan's Avatar
phelan
I love the trick paint! Stripped to bare metal and then clear coated, painted and cleared again, I take it?
jcanrun
Feb 9, 2022 04:40 PM
flips
Mar 16, 2019 12:37 PM
by302404
22
Oct 26, 2017 03:00 PM
jimlowe
Dec 30, 2013 07:35 AM
langlois1
May 19, 2008 12:35 PM
