air
Old Jan 20, 2015 | 03:07 AM
diaedy's Avatar
diaedy
Default air
how much air in front tire on a 2003 1200C are you running?
Old Jan 20, 2015 | 06:35 AM
kingxirol's Avatar
kingxirol
I run between 36 - 40 psi in front and 38 - 42 psi in rear tire.
Old Jan 21, 2015 | 05:22 PM
sporty63's Avatar
sporty63
That depends on the tire. My metzler 888 front I run 36-38. Rear 888 I run 46-50.
Ps...I love the new 888 , the 880s for the front were *****!
Old Jan 22, 2015 | 07:58 AM
Scuba10jdl's Avatar
Scuba10jdl
Stock tire should be 30F/36-40R. If you're running a different tire you will need to consult the maker of the tire for proper inflation.
Old Jul 13, 2020 | 12:28 PM
chief1600's Avatar
chief1600
40/40. Been running this way for 62K on my Ultra. Started with stock tires, then Comander 2s, then another set of Dunlop D402s, now American Elite 3s. Never a problem.
Old Jul 15, 2020 | 02:03 PM
VAFish's Avatar
VAFish
That may be fine for an Ultra, but he asked about a Sportster that is half the weight.
Old Jul 15, 2020 | 04:05 PM
Madnss's Avatar
Madnss
Do you guys run the max psi of your vehicle tires or go by the vehicle manufacturers specs in the glove box or inside of the door? Haha Doesn’t matter what the tire says as long as its capable of holding the air pressure recommended by the manufacturer. Same goes for motorcycles. Tell me i’m wrong....
Old Jul 15, 2020 | 04:06 PM
Madnss's Avatar
Madnss
no it doesn’t, not as long as the max tire psi isnt lower than the model of sportster it calls for.
Old Jul 15, 2020 | 04:13 PM
TUCCI's Avatar
TUCCI
The manual calls for 36Psi on mine.
Old Jul 15, 2020 | 04:14 PM
TUCCI's Avatar
TUCCI
On my Jeep I go 36 all the way around even though it calls for 35 front/32 rear.
