Drive belt life in years..
Old Mar 6, 2015 | 06:02 PM
dustydog2's Avatar
dustydog2
Default Drive belt life in years..
97 xl1200c, 8k miles.....going to replace rear wheel and tire...should I replace the drive belt also? Its spent its off days in a garage and don't see any cracks etc...do they deteriorate like tires?....
Old Mar 6, 2015 | 06:03 PM
Notgrownup's Avatar
Notgrownup
Mines a 02007 with 89000 miles
Old Mar 7, 2015 | 12:52 AM
PanHeadRich's Avatar
PanHeadRich
I had a 2006 with 50k miles on it. So I figured I better call HD and ask if it should be replaced. They told me as long as I don't see any damage of the belt, to just keep on riding. They also told me that the belt life is pretty much indefinite as long as it's been adjusted correctly and you haven't picked up a rock or nail.
Old Mar 7, 2015 | 01:16 AM
John_K's Avatar
John_K
not to mention they're PRETTY D@MN EXPENSIVE to be replacing every few k miles!
Old Mar 7, 2015 | 05:27 AM
grbrown's Avatar
grbrown
Belts have been known to exceed 100k miles, however the thing that can spoil our day is a breakage and to guard against that tension your belt correctly. Check it for example when changing to different shocks and after fitting a new tyre. For this the factory tension gauge is our friend - along with the factory service manual!
Old Mar 7, 2015 | 10:50 AM
Dog812's Avatar
Dog812
I just replaced my 2006 belt. 9 Years isnt too bad. Luckily it broke at my work just pulling out. and not on the road somewhere
Old Mar 7, 2015 | 11:56 AM
LunaticFringe's Avatar
LunaticFringe
put some miles on it, & some hard starts, and if it holds up then it should be good..
I have no experience with this but I sometimes notice dealers will go ahead & replace it on older bike son there show floor
figure your tire is going to last less than 10,000 miles anyway so the belt should atleast last that long. you could replace the belt next time.
Old Mar 11, 2015 | 09:19 AM
mrfikser's Avatar
mrfikser
the belts pretty much last forever...my 2000 still has the original belt and it looks like new..well pretty much like new...
Old Mar 11, 2015 | 02:08 PM
SportyPig's Avatar
SportyPig
Mine lasted around 70,000 miles. Snapped in a parking lot when I dropped the bike into first gear.
Old Mar 11, 2015 | 02:20 PM
Oldcruiser's Avatar
Oldcruiser
I have a 1990 FLHTCU and it still has the original belt on it and it still look's excellent.
gerald martin
13
Oct 17, 2021 06:21 PM
T Man
Jul 30, 2019 05:56 PM
GlennsGlide
Aug 9, 2007 10:55 AM
CBRider
Feb 28, 2007 02:41 AM
DieHard
May 2, 2006 08:01 AM
