wiring problem!!!
Old Apr 11, 2015 | 06:06 PM
spacewok71's Avatar
spacewok71
6th Gear
Default wiring problem!!!
I just got (almost) finished installing a set of handlebars on my 09 1200C and everything on the left is working right but, not so much on the right!! So, I get everything together and went to start it and it started cranking as soon as I hit the run switch and the right turn signal doesn't work either.. any help would be appreciated.. Thanks
Old Apr 11, 2015 | 06:15 PM
Ployd4's Avatar
Ployd4
Pull apart your switch housing and check and recheck everything. Look at the manual seems to me there is a small part in there that is easily lost or not put back in properly. Did you extend cables?
Old Apr 11, 2015 | 06:23 PM
spacewok71's Avatar
spacewok71
6th Gear
I didn't have to take the switch housing apart, I matched all the wires up right but may have missed the mark with the pin connector may have put the wrong wire in the wrong place. yeah I put on 14's
Old Apr 12, 2015 | 09:21 AM
spacewok71's Avatar
spacewok71
6th Gear
Figured out the problem!!! had the wires on opposite side.. of the connector
Old Apr 12, 2015 | 09:22 AM
spacewok71's Avatar
spacewok71
6th Gear
Thanks Ployd4
Hey Man
EVO
Sep 21, 2017 03:21 PM
jst1677
2014-2024 Touring Models
Nov 25, 2015 07:52 AM
JoeBobber
Mar 13, 2010 07:47 PM
nutsandbolts5212
Feb 21, 2010 12:10 PM
kd4tsc
Sep 3, 2009 03:42 PM
