Ignition Module ?
Old May 28, 2015 | 02:38 PM
Dizzyboat1's Avatar
Dizzyboat1
6th Gear
Default Ignition Module ?
Ok just curious here, given the problem of high heat at the ignition module location, and frequent of them failing due to the heat, I was wondering if anyone knows if it is possible to relocate the module to a cooler location on the bike. 03 sportster xl1200c. Like some where near the battery away from the heat?
Old May 28, 2015 | 06:42 PM
HOTLAP's Avatar
HOTLAP
I think it has to be there to pick up a signal from the end of the crank doesn't it? if so, how about adding some ventilation to the location? you could build a custom cover out of wire mesh or drill some holes in your cover with some mesh or screen behind the holes to keep crap out.
jimmyjennings60@gmail.com
Shovelhead
Feb 10, 2019 09:01 AM
texashillcountry
EVO
30
Mar 8, 2015 06:02 PM
JustDave71
Apr 1, 2010 12:28 PM
davzdorado
Jul 3, 2006 01:22 PM
Keith
Aug 29, 2005 12:56 PM
