Brake Help!!!
Old Jul 8, 2015 | 12:43 PM
Jackpoticorn's Avatar
Jackpoticorn
Default Brake Help!!!
Picked up a 1998 Sportster last week. Guy took real good care of it, had the brakes checked and bled by local indie shop before handing it off to me.
I've noticed a knocking sound coming from the front end. Thought it was coming from the engine, then I thought it was a loose horn bracket...but now I'm convinced it's the front caliper.
The noise stops when I apply the front brake (while in motion). So I figured the caliper must be loose. Went to tighten it down today and the bolts holding it to the left fork are as tight as they can be...but I can physically move the caliper back and forth with my hand - not much, probably a half a millimeter at most, but enough to say the caliper seems wobbly?
It's the older style caliper so maybe it's supposed to have a slight movement to it? I wouldn't be concerned if it wasn't for the constant audible knocking sound while riding. Also, the noise intensifies when I go to make a left-hand turn, weird I know but definitely noticeable!
Any help appreciated.
Old Jul 8, 2015 | 01:11 PM
Iarecobra's Avatar
Iarecobra
I have a 98 sportster as well. Just went out and checked my caliper. There is a little play in it. But they are "free floating" calipers.
If it knocks when your moving the caliper you could try bleeding the brakes again. Might still be a little air in the system causing them to move a little more then they should.
Old Jul 8, 2015 | 01:49 PM
Scrmnvtwins's Avatar
Scrmnvtwins
check the runout on the rotor, could be warped and making a knocking sound as the wheel spins the rotor through the caliper
Klasbu
Jun 8, 2018 02:19 AM
jimmers1817
May 2, 2011 06:01 PM
MOSTWANTED
Sep 18, 2008 02:23 PM
AKtanker
Jun 14, 2008 01:17 PM
69Shark
Feb 25, 2007 09:45 AM
